i do, every time i wash the car
and inbetween when its not possible, wheel cleaner inside the wheel and pressure wash off
Wheel Cleaner Brush
I agree, the outside needs cleaning mainly to keep the car looking smart, the inside is a bit more important as if you let the corrosion build up at the ends of the spokes then the strength of the wheel will eventually be less - that is why I suggested using the slightly stiff Kent sort of loop ones and bend them to suit as I did. They are not anything like as hard as some of the Halfords wheel brushes - my mate's wife gave me one of these Halfords ones as a present - its handy for scrubbing the plastic wheel arch liners only!Jeff GTi wrote:i do, every time i wash the car
- KennyPOLO_Gti
- KennyPOLO_Gti
- whitegtipolo
Oh well then, so you've never seen the inside of "forgotten" wheels then? Even after using wheel cleaner the wrinkly stuff is really the coating lifting and letting water and salt in - and the alloy does not like that at all!whitegtipolo wrote:sorry but that is a load of cack!!!RUM4MO wrote:
- KennyPOLO_Gti
