New is good lol
Ill be on soon bud!
Help Please? Throttle problem with GTI
thanks so far guys.
I drove the car today, no problems at all. Then on the way home after work, once the temp was up alittle in 4th at say 3,000rpm it just started to hesitate
I'm not sure is the cam angle sensor replaced by the previous onwer was actually an original part, also not sure about air mass.
Its jsut very annoying. Any advice really helps
Just had the car plugged into my local garage tech machine (not vw) and its showing mis-fire on ignition number 3.... this leads me to believe its a coil packMike_M wrote:It could be a faulty coil pack as mine used to gain and loose power unitl I changed it due to being corroded etc
Not using the polo while its faulty and this means the garage cannot look at it until thursday next week
Going to have all the spark plugs at the same time.
Any other advice would be welcome.
weirdbeardmt
Re: Help Please? Throttle problem with GTI
How corroded do the terminals in the coil pack have to be before you would start seeing problems with the performance? The top ones on my GTi are perfect, shiny and smooth, but the bottom ones look like they are coated in white powder. I got a bit of wirewool in there and some wd40 and they looked a little better - am I better off just buying a new one and being done with it?
if its white then thats signs of leaking, limescale type stuff, i would get a new one!
