Its very easy to use as it comes with full instructions, as I said it comes with a list of VAG codes but there are better lists available FOC on the internet - I can point you in the right direction if you buy one. I bought mine directly from Gendan - at least that way you are buying from a proper scan tool distributor.tim80bwi wrote:Deleted.
EDIT: How easy is the interface to use on the Gendan device? I take it you need to device itself and a code reference list?
No power
