Headlight Switch Mod
Re: Headlight Switch Mod
To remove the light switch push it in then turn it to the side light position, you should hear a click. Now you should be able to take it and and may even see how it works..
si-gti
my initial 40 views post was a little impatient i agree
my subsequent posts werent aimed at the forum itself but at the patronisng statements that assumed i wanted to cruise round with my driving lights on when they werent required.
my apologies to other forum members
Like father like sonmwbpsx wrote:the offence you would be charged with is 'improper use of lights'
it is a fine and no points
you turn over the fixed penalty notice and write: I wasnt using my lights improperly
you wont even get a reply!!!
this is fact my son had the very ticket
tim80bwi wrote:Like father like sonmwbpsx wrote:the offence you would be charged with is 'improper use of lights'
if you are going to quote my posts please quote the full post !!!
The actual wording of the offence is causing undue dazzle [to oncoming traffic] and it is a £30 fixed penalty (no points) and the undue dazzle part comes into play because you are outputting more than the allowable 110W of light [to the front]. Your driving lamps (or whatever you wish to call them) would be no lawful excuse [if the weather is clear] and you are using them because with your dipped beams AND the fog/driving lamps you are exhibiting more light than is required and hence the offence is complete.
I'm going to guess that you're the sort of person that doesn't believe in dipping your main beam to oncoming traffic either.
Why? It's not as if it has taken it out of context....mwbpsx wrote:tim80bwi wrote:Like father like sonmwbpsx wrote:the offence you would be charged with is 'improper use of lights'
Maybe I've missed a turn here, but, typically this is the blurb used to sell European types of light switches into the North American market. So, in other words, this switch is exactly the same as the one currently fitted to 9N UK spec'd cars with front foglights.
