Free link to ETKA
ag69
Drives: 1.2TSi 77Kw 7DSG
Re: Free link to ETKA
Post by ag69 »
Thank you very much. This is much more detailed than other links.
One question which I could not solve for what does the REMARK like -BY, CH, GN, MM, MN stand for? This is marked for Steering.
Navigate -- >
English --> Volkswagen --> EU --> PO --> 2015 F+ --> 4 --> 419-20
this is marked.
ag69
Post by ag69 »
one more query regarding part number "4D0971636"
On Car part catalogue site if we go to :
English --> Volkswagen --> EU --> PO --> 2015 F+ --> Electrical Systems(9) --> Central wiring set area: dash panel , individual parts (971-83)
and then scroll down to find "4D0971636"
There are following part Numbers mentioned :
4D0971636 -- color Black
4D0971636A -- color Brown
4D0971636B -- color Red
4D0971636D -- color Blue
So are they just marked different based on color?
All are 6 pin flat housing used for switches in center console ie heated seat, esp, hazard, parktronic button/switch.
different colors with different notches so you don't accidentally fit the wrong plug in the wrong switch.
ag69
Post by ag69 »
Thanks iichel.
not sure if this conversation should be here on my or some other thread.
But please feel free to delete/move it in that case.
I have 4 empty switches and wish to put in these switches out of 7 places.
They are like this from left to right:
empty - esp -- defogger -- hazard -- empty -- empty -- empty
I have procured 4 switches:
Left heated Seat,
Right heated Seat
Parktronic Switch
Auto On Off Switch
My intention is to install them:
So during day time all console looks neat ie no dummy switches.
and at night or once turning lights ON. They all illuminate ( not do any function). Use pin 3 and pin 6 for powering it on for this.
Something like this:
https://www.drive2.ru/l/4324686/
Etka mentions different number for them. But all have basic same 6 pin layout.
So i was be buying 4D0971636 adapter for above (ie left and right heated seat, park tronic button and auto on off switch).
These are the item in question:
http://allegro.pl/kostka-zlacze-wtyczka ... 49211.html
Similarly :
http://www.carsystems.pl/?f=&a=sklep&k= ... 6+&x=0&y=0
yeah when i switched from 6R to 6C ventilation outlets with 6C buttons, I re-used the 6R buttons and simply cut off the notches and made a label (physical label with the dyno label maker). this way they all work too..
ag69
Post by ag69 »
thanks for reply iichel.
So 4D0971636 can satisfy my need.
Since these parts are not available across the counter to check working or not.
I keep on reading and then asking qs before procuring them.
ag69
Post by ag69 »
My rear lid has no camera in VW emblem. Part number is 6C6827469 (it is 110 mm wide)
So two questions here:
1) Does reverse view camera from Passat, Golf and Beetle can fit Polo 6R ?
2) Also i could not get exact part number but is it possible to get camera unit (with motor) and fit in existing emblem?
Not sure if it is worth hassle than buying entire unit.
Here are some of part numbers I could find passat and golf for different model year:
  • 3G0827469<and suffix>
  • 5GM827469<and suffix>
  • 5G0853630<and suffix>
Here is a link where entire set is listed:
http://www.carsystems.pl/vw-rear-emblem ... d1442.html
As per this link, 5K0827469AQ camera part listed is also used for following cars in addition to VW Polo 6R:
  1. Passat CC B6
  2. Golf 6
ag69
Post by ag69 »
Passenger Glove Box -- 6RF857121C/H
Does any locale get a glovebox which opens in slow action?
or do we have to something like this:
https://www.drive2.ru/l/7060620/
using Toyota 55557-60010
[youtube]https://www.youtube.com/watch?time_cont ... VSxSb5xWg0[/youtube]
ag69
Post by ag69 »
iichel wrote: Mon Aug 28, 2017 11:50 am different colors with different notches so you don't accidentally fit the wrong plug in the wrong switch.
finally i got the connectors in hand today. iichel you were (as always) right!!!!
Since I ordered all "4D0971636" which are in black color. Hoping they they would fit and slide. But the notches don't align and hence block the entry in (back of) switches.
ie Left and Right heated seat, Auto On Off switch and Parktronic switch
Front side of switches:
back side of switches:
Connectors:
Easier solution is to cut the part of side notch which is not sliding in the respective buttons than finding appropriate connectors.
Seems my imaginations and assumptions are way to wrong.
So unfortunately it is not going to be hot knife in butter kind of job but with some work around.
However on plus side, at least I have switches and necessary connectors.
I would try to upload a video so other people wont have face same issues.
Whats the part number on each of those switches? Ill be able to find the appropriate plugs you need :)
ag69
Post by ag69 »
alexperkin, thank you very much for the offer.
4 switches I have have following part numbers:
1) 6R0963563 -- Left Heated Seat
2) 6R0963564 -- Right Heated Seat
3) 6RU927122 -- Parkrtronic
4) 6R0905218 -- Auto On Off
However I did manage to do a workaround, I removed outside shell and now without notches to worry the inside connectors slides and sits properly.
here is how it looks after removing outer shell
this is how the switches look once you insert inside plastic which has wires
Pipefoto
Drives: Vw polo 1.6 TDI
Post by Pipefoto »
Mouse_GTI wrote: Sun Feb 22, 2009 8:49 pm http://www.vagcat.com/
I know a lot of people already know about it but a useful link for those who don't 8)
ETKA with images.
http://ifinterface.com/page/page3.php?langid=2
Carprog---->loading---------close message (always)---------select your language------- model-for vw polo select PO----and to search for what you need.
Clicking twice on the reference you get the price but I think it's without tax. And clicking on the number in the image you get the reference highlighted in the right dialog.
It is continually updated.
PR codes:
http://prsearch.planetvag.com/
and to finish .............http://volkswagen.workshop-manuals.com/
very interesting the link thanks
