UK-POLOS.NET - THE VW Polo Forum • my brand new headlights - Page 2
Page 2 of 3
Re: my brand new headlights
Posted: Fri Feb 27, 2009 10:35 am
by Tim_GTi
They look great! Would definitely get some if i owned a 9N3
Posted: Fri Feb 27, 2009 7:21 pm
by whitegtipolo
i want em but dont wanna strip my lights down and then they steam up etc as we have lots of rain over here!!! But defo a future mod! :D
Posted: Fri Feb 27, 2009 9:29 pm
by monk
if you seal them up right you wont have any problems. i washed my car yesterday and there was no steam. ill keep you briefed if something comes up.
Posted: Fri Feb 27, 2009 10:05 pm
by alexperkins
Newer lights have vents on them to prevent steaming up, so they should be ok.
Posted: Sat Feb 28, 2009 10:28 am
by brad mole
when you say nothing can go wrong with fitting, does that mean there is only one way these will fit in? because i would assume that the beam pattern would be knocked out completely?
alexperkins wrote:Newer lights have vents on them to prevent steaming up, so they should be ok.
mine get condensation on the front and the back :(
Posted: Sat Feb 28, 2009 1:37 pm
by alexperkins
Check the rubber drain bits are firmly secured and the back of the headlight is sealed properly
Posted: Sun Mar 01, 2009 2:04 am
by zedzo
them lites are on fire! ! ! !
some one needs to buy them, convert them and then sell them me for 30 quid :lol:
Posted: Sun Mar 01, 2009 9:04 pm
by monk
brad mole wrote:when you say nothing can go wrong with fitting, does that mean there is only one way these will fit in? because i would assume that the beam pattern would be knocked out completely?
there is only one way you can fit them... the projector has at its back form of some sort that will fit only in the correct position. just like the lightbulb. you can't put the lightbulb in any other position then the correct one.
Posted: Sun Mar 01, 2009 9:12 pm
by whitegtipolo
so in theory you can adjust the beam same as normal! :P
Posted: Mon Mar 02, 2009 10:16 am
by monk
not only in theory, but also in reality :)
you can adjust your beam just the way you did before from inside the car for the sensitive part and from under the bonnet roughly. just like before.
Posted: Mon Mar 02, 2009 12:20 pm
by 8080
These look like a very smart solution.
I'd have no worries about opening up headlight. I did it with my old halogen headlights when an adjuster broke inside. It was simple, just a matter of going round the sealant with a hairdryer and a knife. There were no fogging problems with them afterwards
I asked hids4u about them there, they said they have no plans in the short term to sell them, but might look into them in the future
Posted: Mon Mar 02, 2009 5:45 pm
by whitegtipolo
one question how do you change the bulbs??? :o
Posted: Mon Mar 02, 2009 7:43 pm
by lillayzee
What are the normal headlights called? :oops:
is it possible to get the 'blue and white' look without changing the lights?
Sorry for hijack of thread!
Posted: Tue Mar 03, 2009 12:26 am
by monk
@whitegtipolo just like the normal bulb. the lightbulb is in the back of the projector and it isn't a problem.
@lillayzee i think you are referring to the halogen ones ...
you can get that effect but not as white as these ones. go to a petrol station or somewhere you can find light bulbs for your car and ask for Phillips Blue-Vision. they are considerably bluer than the normal halogen lights, but not as "ice-blue" as the xenon 6000k.
Posted: Tue Mar 03, 2009 7:39 pm
by Tim_GTi
lillayzee wrote:What are the normal headlights called? :oops:
Your referring to HIDs. You can buy retro-fit kits. and it'll give you this effect. Projector lens' enhance this refraction even further.
