Page 2 of 2
Re: ABS Light + Handbrake Light Flashing
Posted: Fri Feb 26, 2010 7:15 pm
by polokaj
Yup checked the internal fuses.
I watched him do the work, he basically rewired the aftermarket harness and never messed with the actual wiring!!
Posted: Fri Feb 26, 2010 7:22 pm
by alexperkins
Hmm it could just be coincidental. where abouts are you located mate?
Posted: Sat Feb 27, 2010 12:04 pm
by polokaj
I'm in stockport, The VAG cable arrived yesterday, i'll see what it says and let you guys know. Thanks
Posted: Sat Feb 27, 2010 2:33 pm
by polokaj
This is what the diagnostic said:VAG-COM Version: Release 409.1-US
Chassis Type: 6N - VW Polo
Scan: 01,02,03,08,15,17,19,25,35,41,45,46,55
Address 01: Engine
Controller: 036 906 033 A
Component: 1.6l/4V SIMOS3 00HS3259
Coding: 00031
Shop #: WSC 00788
5 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17526 - Shareware Version. To Decode all DTCs
P1118 - 35-00 - Please Register/Activate
16524 - Shareware Version. To Decode all DTCs
P0140 - 35-10 - Please Register/Activate - Intermittent
17927 - Camshaft Adjustment: Bank 1: Malfunction
P1519 - 35-10 - - - Intermittent
16384 - Shareware Version. To Decode all DTCs
P1519 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0010 1001
Address 03: ABS Brakes
Controller: 6X0 907 379 C
Component: ABS/EDS 30 IE CAN V004
Coding: 15603
Shop #: WSC 00788
It says no fault on the ABS, now I'm really confused!!!
Posted: Sat Feb 27, 2010 3:41 pm
by alexperkins
clear the fault codes and rescan
then we can look at problems that are persitant
Posted: Sat Feb 27, 2010 4:33 pm
by polokaj
Ok I now get this:
VAG-COM Version: Release 409.1-S
Control Module Part Number: 6N0 920 904 K
Component and/or Version: KOMBIINSTRUMENT BOO V05
Software Coding: 00444
Work Shop Code: WSC 00735
1 Fault Found:
01316 - ABS Control Module
49-00 - No Communications
So any ideas on how to fix it, checked all the fuses, what else could it be, maybe the HU issue I mentioned before, can't be a coincidence or can it?
Posted: Tue Mar 02, 2010 3:54 pm
by polokaj
Any ideas?
Posted: Tue Mar 02, 2010 6:32 pm
by alexperkins
The ABS module isnt getting any power. Try scanning the engine controller seperately, then the ABS controller seperately. Doing a full scan somtimes obscures the outcome.
Posted: Mon Nov 21, 2011 11:15 pm
by EUMANIA
i also have this problem help?...how to fix it done the above but doesnt seem to work i havent put it on a vagcom or that to check actually what the fault is though
Posted: Sat Nov 26, 2011 12:32 am
by benmkiv
Vaccine is always first port of call mate. Could be faulty sensor or I k ow with the ABS the fuses on the battery are very common to fracture
Posted: Sat Nov 26, 2011 1:35 pm
by Trottagti
Mine was doing this and it turned out to be my brake light switch on the pedal box..
May be another area to check, seems odd though....
Posted: Sat Nov 26, 2011 2:46 pm
by NotRich
I've come across a few with that fault, first time I tried a few things, ended up pulling the ABS ECU off the bottom of the pump and replacing it.
Solved the problem.
