Dub_Dan wrote:K.I.T.T this is what its all about dude! im intrigued to know about both of your cars! only thing i hate about the diesel is first and second ratios being so short! and you have my vote towards another tdi discussion!
Not much to know about my car...It's a 1422cc TDi with 75 BHP stock
. Basically a PD100 minus one cylinder. It's been mapped and was dynoed in March and put out 104.5 BHP (I reckon it's got a few more ponies in there...we came to the conclusion the dyno operator was errr...incompetent).
It's by no means fast. Nippy? Ish. I'm aiming to build the UKs fastest 1.4 TDi once uni's out of the way and I've got some cash coming in. Everyone says don't bother, put a 1.9 in, but I just want to prove them wrong
Regarding the 1.9, what do you want to know? I know Ruan said he wanted to put a PD130 head on his, but in reality, there are PD100s bordering on 300 BHP. You've just got to uprate a few parts, conrods being the most significant. The PD130/150 conrods are better than the PD100 ones, but I'm not sure by how much. I need to read up on this as the 3 cyl PD75 shares quite a few components with it.
Stock PD100 + stage 1 remap = ~140 BHP. Swap over to a PD130 (GT1749VA) or PD150 (GT1749VB) turbo and you're looking at ~160ish BHP. You've reached the limits of the injectors then.
PD130/150 (same part no.) injectors are good for 210 - 260 BHP depending on who's dyno you want to believe
The general consensus is 220ish BHP is the max 'safe' limit for these injectors. In combination with PD130 / 150 turbo and a FMIC, the injectors will get you to ~175ish and 190ish BHP respectively. You an get over 200 BHP, but you need a
(very, very) good tuner Stock SMIC only good for ~170 BHP.
After that, things get a bit more expensive. A GTB1756VK (from a 2.7 TDI) combined with these injectors should get 220 BHP, maybe a bit more. If you wanna get really serious (and have the budget), you need Bosio Race 783 nozzles to be swapped into your injectors and a GTB2260VK...should be good for 300 BHP, albeit without modifying the head (porting, etc) I'm not sure if you can get more than 270ish. The most I've seen was a mk4 Golf which came to the dyno day in March. Putting out 266 BHP with the 2260 and 783 nozzles.
The more you boost, the 'bigger' the MAP sensor you need, but that's not a big issue. < £25 for a 4 bar one which is the most you'll EVER need.
That's it in a nutshell. Also bear in mind the stock PD100 clutch won't hold much more than 350 NM of torque I think.
Best bang / buck I'd say is 1749VA/B, PD130 injectors and FMIC.
Ash
