Pic request - GTi's on 16" BBS RXII's
Re: Pic request - GTi's on 16" BBS RXII's
All the 16 RX2s in 4 stud are the same offset. I think it’s ET38.
With a 195/40/16 tyre you could probably put a 10mm spacer on the back quite comfortably
6n2stan
Drives: 6N2 GTI, Golf GTD + R32, T5.1 BiTDI DSG
Post by 6n2stan »
The wheels shown above were off the mk3 golf and the mk3.5 Cabrio golf. They are a straight swap as they are 4x100 pcd.
You can put spacers on the rear if you want but you need to consider buying longer wheel bolts. Also if you have a lowered car the ‘tuck’ may come in useful for clearance so spacers might cause you issues with arch damage etc.
Mike_Galv
Drives: 6n2 GTi
Post by Mike_Galv »
Thanks for your help guys!
I am considering lowering the car but I think I'll get some 16" wheels first and see how they fill the arches. Then if I do decide to lower the car I'll have a better idea of how low I can go, I don't think I'd go very low because I don't think the roads where I live will allow too much :( then I can think about spacers afterwards if needs be.
6n2stan
Post by 6n2stan »
It’s a shame to lower GTI’s too much IMO as you can’t drive them as intended. It’s ok if you’ve got a 1.0l 6N2 as it makes no difference :lol:
My gti was down 35mm on 16s and it was just right
Turbo Tony
Drives: 2001 6N2 GTi
Post by Turbo Tony »
Wow, those 16s look gorgeous!
