CUBBY BOX/COIN HOLDER
bstardchild
Moderator
Re: CUBBY BOX/COIN HOLDER
Post by bstardchild »
Verity wrote:Image
Really!! Number 3 & 4?
(Sorry for bad photo on iPhone and some odd paint app)
What is the thing between 3 & 4 for - I've never worked it out :shock: Sorry but I haven't and I've never been bothered to take a picture and ask either but as you have I'll thread jack slightly :wink:
Verity
Post by Verity »
The bit just above the climate control/ heater controls?
It's a coin holder. You know there's little slits in the sides your meant to put coins in them. Tho personal I Keep my head unit remote in it and keep my money in the ash tray lol
"stowage area with coin holder" to quote the handbook.
cornishdrummer
Post by cornishdrummer »
Thats what i want to replace the coin holder with slits.
The pic, is diffrent to the inside of mine
dub6n2
Post by dub6n2 »
cornishdrummer wrote:Thats what i want to replace the coin holder with slits.
I think there's nothing you can replace that coin holder with, its not a DIN size so nothing else fits in it afaik
Verity
Post by Verity »
So you are missing 3 & 4? Cup holder and coin/storeage tray?
You should be able to buy the hole lot from a scrappy/ eBay/ VW.
Meaning the cup holder, coin tray, and the bit that screws onto the dash that holds them.
Or scarfrice the large cubby and do what Emma did instead.
All the coin stowage bit is good for is for coins, little remotes ;) , USB connectors ;)
It's just too little for anything else
cornishdrummer
so can 3 & 4 be added ?
Verity
Post by Verity »
Tbh I've never know that section not to be there. I've had 3 6n2s and been inother peoples and never not seen it. Even my mate has that section in her Lupo E- except her buttons are there instead of the cup holder and coin tray. It's also pictured in the handbook. So I would have thought it would have originally been in your car, but removed for some reason.
By memory that section is just held on by two screws and some little clips at the back that help keep it in place.
So should be nice and simple to put one back on.
cornishdrummer
Will have to have a good look morro i think
cornishdrummer
Have had a look and def not got it, but there is def room for one and there is screws in the big cubby box so im guessing I could fit one with out many probs.
Verity
Post by Verity »
good good. should be pretty easy. its just getting the screws in the holes which is the hardest part sometimes ;)
This is what the section looks like. as you can see there are two clips at the back. they are ment to be hidden. but last time mine came off i didnt notice that one of the clips was sticking out so i need to sort that out at some point.
and you can see the holes for the screws
cornishdrummer
Seems that mine should have that. Mine looks diffrent to yours, whats under the coin slot thingy ?
Verity
Post by Verity »
I have a GTI, so I've got Climate Control instead of heater dials
cornishdrummer
oh right. so is it not only the 6n2 GTI has the drink holder ?
Verity
Post by Verity »
Nah deff not. Coin tray and cup holder as standard, I've had an E which is the simplest of all models and that still had them. The GTIs have climat control and different clocks, everything else is the same.
cornishdrummer
Thanks for your help I will try and hunt one down/ :D
