UK-POLOS.NET - THE VW Polo Forum • Help!!! - Page 2
Page 2 of 2
Re: Help!!!
Posted: Mon Aug 01, 2011 4:24 pm
by eviljohn27
ritey ho. I'll have a snoop around under the bonnet on my day off. Thanks for all this info by the way. I really appreciate it. So if the weber carb isn't that great, is it worth just stickin with the stock one or is the pierburg one a better investment? I've found a brand new electronic distributor too. Is that worth switching and if so, is it a straight trade for the one that's on there already, or will the new one need extra doohickeys?
Re: Help!!!
Posted: Mon Aug 01, 2011 6:06 pm
by steveo3002
you need more than the dizzy...i dont know enough to advise on that
webers are great , way easier to tune than a pierburb , but nothing wrong with a fully working pierburg, its just they play up often and are hard to fix
Help!!!
Posted: Mon Aug 01, 2011 10:22 pm
by benmkiv
Pierburg are what was fitted standard. At least It was to the mkii's and personally had a lot of trouble tuning mine too
Re: Help!!!
Posted: Tue Aug 02, 2011 3:30 am
by eviljohn27
So the current carb will be fine until I can beg/borrow/steal a weber. Good to know. I'll ask around about the distributor. Someone out there must have the answers. How do you go about tuning a carburettor? And what does that do? Better fuel consumption? Is it harder with a manual choke? Cheers guys.
Re: Help!!!
Posted: Tue Aug 02, 2011 8:13 am
by steveo3002
tuning it would be ajusting the air/fuel mixture to the correct ratio , setting the idle speed and fast idle
hard to do on a pierburg..fairly easy on a weber
obviously being set up well makes it run at its best and use the least fuel
you might wana check the filler neck on your petrol tank , this is common to rust so bad that they leak , if yours is sill good then treat it before winter , rust paint /underseal /underbdy wax etc
Re: Help!!!
Posted: Tue Aug 02, 2011 3:13 pm
by eviljohn27
amayzun! I'll find out what's in place for sure and add getting that fiddled with to my ever growing to-do list. I'll check the petrol tank when i get it up to do some other stuff to it on friday. Thanks again gents. Any other info/advice you can give about anything else on my beige beast would be quality. Even if you think it's insignificant but you tried it and it worked.
