Mine does this too. Misfires like mad when cold, till I blip the throttle/put it in neutral & floor it, and it's fine for the rest of the journey again, gives full power and pulls well - really, really irritating.
Mines had a new coil, did nothing, leads are fine, so not an issue, no fault codes either. The strange thing is it only does it when the car is stone cold - if I come back to it after an hour or two, it won't do it - it's only after 6+ hours it seems to play up. Hope you find a fix for it though, would be interested to know the cause of the issue.
Help needed on last straw with polo but dont want to give up
TriggerFish
- Location: Aylesbury, Bucks Drives: Polo GTi, 330d 'M-Sport'
- HD9POLOGTi
Ok mate ive just been told it maybe the map sensor playing up gona locate and clean it on monday ill let u knoTriggerFish wrote:Mine does this too. Misfires like mad when cold, till I blip the throttle/put it in neutral & floor it, and it's fine for the rest of the journey again, gives full power and pulls well - really, really irritating.
- red6n2
I had thus issue changed the coil pack and engine temp sensor and it's fie mine was with a 6n2 though.
- HD9POLOGTi
Mines a 6n2 as well pal and ive replaced pretty much everything my last option ive just been told about is the map sensor any tips on cleaning it ?? I have some electrical cleaner spray would that work and were abouts is it and what am i looking for?red6n2 wrote:I had thus issue changed the coil pack and engine temp sensor and it's fie mine was with a 6n2 though.
TriggerFish
Re: Help needed on last straw with polo but dont want to giv
Fingers crossed for you! And thanksHD9POLOGTi wrote: Ok mate ive just been told it maybe the map sensor playing up gona locate and clean it on monday ill let u kno
If you look down the side of the inlet manifold, to the left side, you'll see a sensor that goes into it. Its held on by hex bolts / torx wtv you call them, and there isnt much space to get it out either. I sprayed some electrical contact cleaner from halfrauds onto a cotton ear bud, and patiently took my time to clean the sensor out.HD9POLOGTi wrote:Mines a 6n2 as well pal and ive replaced pretty much everything my last option ive just been told about is the map sensor any tips on cleaning it ?? I have some electrical cleaner spray would that work and were abouts is it and what am i looking for?red6n2 wrote:I had thus issue changed the coil pack and engine temp sensor and it's fie mine was with a 6n2 though.
Word of warning..
DO NOT USE CARB CLEANER TO CLEAN THE SENSOR.
