Re: Auto windows up & down via key fob.
Posted: Tue Mar 13, 2012 6:39 pm
soon as i got home i tried is and it works a treat
Probably the Worlds greatest Polo resource
https://uk-polos.net/
CupraTdi_ wrote:Not so good when u do it accidentally and its raining like i did with my dads audi lol sat for hours outside with them all the way down
now that is good !!! the boot comes up quite fast haha it would defo knock someone over if they are standing too close to your pride and joy hahaBoyracer_2011 wrote:Aye the boot button is canny crap really.
I seen this vid on YouTube, shame it dosnt come as standard on our polos![]()
https://www.youtube*.com/watch?feature=en ... DP6qA&NR=1
Haha now that would be funny.. Id luv to have this tho.The Sheriff wrote:now that is good !!! the boot comes up quite fast haha it would defo knock someone over if they are standing too close to your pride and joy hahaBoyracer_2011 wrote:Aye the boot button is canny crap really.
Assume its a retro fit? I didnt see it as an option?Boyracer_2011 wrote:Aye the boot button is canny crap really.
All of the windows need to be in "one touch" mode, where a single press of the switch will lower/raise the window completely. If any of your windows don't do this then lower that window & keep the swicth operated for a few seconds. Then raise it & again hold the switch. After that, "one touch" operation should be enabled for that window. Once all four are in that mode then the open/close from the fob should work.limparka wrote: Thu Sep 24, 2020 5:34 pm Anyone have some suggestions what should I check?
Best Regards,
limparka
Thank you rbz5416!rbz5416 wrote: Fri Sep 25, 2020 2:26 pmAll of the windows need to be in "one touch" mode, where a single press of the switch will lower/raise the window completely. If any of your windows don't do this then lower that window & keep the swicth operated for a few seconds. Then raise it & again hold the switch. After that, "one touch" operation should be enabled for that window. Once all four are in that mode then the open/close from the fob should work.limparka wrote: Thu Sep 24, 2020 5:34 pm Anyone have some suggestions what should I check?
Best Regards,
limparka
