The headlight washers only operate with the headlights on when you wash the windscreen. There also needs to be enough fluid in the reservoir
You can't adjust the time they operate. They will work every time you wash the screen with the lights on. A bit irritating!
Rear washer not working.
Aquavalver
- Drives: 2013 Polo Blue GT
Re: Rear washer not working.
Ah! I'll have to have a look as never seen them work yet!alexperkins wrote:The headlight washers only operate with the headlights on when you wash the windscreen. There also needs to be enough fluid in the reservoir
