Page 2 of 2
Posted: Fri Jun 18, 2004 10:12 pm
by poussou
waynesGTI wrote:I know what u mean when i went out in the snow u could here a grinding sound every time the wheels spin but i have no ESP or EDL light on my dash? so have i got EDL or not?
Yes you do mate.....Enjoy
Posted: Fri Jun 18, 2004 11:16 pm
by Josh_PoloGTi
OK, is this why sometimes when you do a "spirited" start from the lights, it will sometimes bog down a bit when the wheels start to spin?
Posted: Sat Jun 19, 2004 12:37 am
by snoopstah
Sounds more like traction control that - EDL should never 'bog it down' as it should never do anything other than brake one of the front wheels. Traction control on the other hand cuts the power to the engine.
I've never noticed mine 'bog down'. You shouldn't even trigger EDL in a straight line, because both of the wheels will spin.
Posted: Sat Jun 19, 2004 12:38 am
by poussou
Well as far as i know the ECU cuts of the engine also along with the ABS thingy.That could be what you are experiencing...
By the way....does anyone know the standard fuel pressure value for the Gti???
