MFSW buttons.
Re: MFSW buttons.
yes..
FriKkels, it is possible, but it is not correct. You can see in this post (takes to load images)
I think the arc joining the buttons do not fit well.
http://www.polovw.it/foro/viewtopic.php?f=59&t=22570
but then:
http://www.polovw.it/foro/viewtopic.php ... 68#p654583
Re: MFSW buttons.
FriKkels wrote:Thanks Ciclo,
One more Question, the display in my picture(the one with the fuel gauge on the bottom) is that the medium mfa or what is that called? I can scroll through some settings using the stalk.
Regards,
correct me if I'm wrong, I think same as that of chrispy. DIS.
Look in the user manual as it is called in English.
crosspolo2014
MFSW buttons.
Post by crosspolo2014 »
Regards,
Hello ciclo,
I have a quistion hope u can help me.
I this right?
Re: 6R - Multifunction Steering Wheel Retrofit
Postby diskoboy » Tue Oct 07, 2014 3:25 pm
The LIN-BUS can also be found on T28a/16 (connector to the driver door LHD cars). Perhaps it's easier for some :-)
And where to find this connector????
Many many thanxs!!!
Re: MFSW buttons.
Yes, that's right. :wink: (for RHD would be T28/16)
It is located in the connector on the driver's door.
For example, to LHD:
crosspolo2014
MFSW buttons.
ciclo wrote:Yes, that's right. :wink: (for RHD would be T28/16)
Yessssss thank you ciclo,
Now i can install my mfs steering wheel.
It is easy then on the BCM.
