Bi-Xenon upgrade help
Tooks
Drives: 2011 Polo GTI
Re: Bi-Xenon upgrade help
Post by Tooks »
CrypticG wrote:Apologise for the maybe silly question..
How come Xenons require a self-levelling system? What does this add or bring to make them legal?
Where does it go and what is it? :oops:
I have headlight washers so that shouldn't be an issue.
It's not a silly question at all.
Basically, two sensors are fitted to the from and rear axle, and these determine the loading of the car when the ignition is first turned on and the lights automatically adjust to set the correct height. The intention is to ensure the xenons, which are incredibly bright compared to halogen bulbs, do not dazzle oncoming drivers too much. Eg, if you have two guys in the back, with some luggage in the boot, the car will be nose up, so the system points the lights down a little.
It doesn't dynamically adjust the lights for bumps and undulation, which is why you will still see the beam cutoff going up and down whilst driving, but that's the same as any other car.
Cars fitted with self levelling don't have a level adjuster in the car by the light switch, the system takes care of it.
MOT testers are supposed to check for self levelling function on xenon equipped cars, along with headlight washers, the latter are easy to check for and their operation, but I understand they are allowed to give the 'benefit of the doubt' with regard to the presence of fully functioning self levelling as it's difficult to check at the MOT station.
As long as the lights are correct set/aimed, they would pass if the washers are working most of the time. I know it's a developing area of legislation, the authorities get a lot of complaints about it and they are slowly but surely tightening the noose around aftermarket systems.
CrypticG
Drives: 1.2 TSI SEL (6C)
Post by CrypticG »
Tooks wrote:It's not a silly question at all.
Excellent description, thank you! So I take it a self levelling system would be a pain to install, especially if coming from the back of the car to determine loading.
Tooks
Post by Tooks »
Unfortunately, I think it would be quite involved and quite time consuming!
On the old A3 forum I used to frequent, a couple of guys did retrofit it, using OEM sensors, ECU and wiring etc. I think it was almost 'plug and play', but required coding and a lot would depend on how the 6R/6C system works ie is it a self contained ECU or does it work with the main ECU/BCM, and would certainly involve some coding.
I think it's one of the reasons the factor xenons are quite expensive, it's not to make them 'exclusive', it's because of the additional complexity and fitting of self levelling and headlight washing, and in the Polo's case the corner lighting as well I guess.
Like most things, I'm sure it could be done retrospectively, whether it's cost effective is highly debatable!
CrypticG
Post by CrypticG »
ahh i see, fair enough then lol. thanks :)
Here is a good DIY in Golf:
http://www.vwgolf.net.au/showthread.php ... de-and-AFS
http://www.kufatec.de/shop/en/volkswage ... vw-polo-6r
Install in Polo is quite similar. The time to install is not important if you really wish to make this retrofit.
