My Polo 1.2 TSI DSG
thealbert
Drives: polo 6r 1.2 tsi dsg
Re: My Polo 1.2 TSI DSG
Post by thealbert »
Plastic!
Please thealbert, can you show here the pictures about retrofitting dimming rearview mirror and light sensor? Thank you in advance. :wink:
With your permission. :?:
Images installing dimming mirror made by thealbert.
Wiring installation:
https://drive.google.com/file/d/0B2nv91 ... VndzQ/view
Link. e-g:
http://www.aliexpress.com/item/OEM-Orig ... 97585.html
thealbert
Post by thealbert »
Ok Ciclo, good job!
Thank You. You did a good job with this installation. 8)
thealbert
Post by thealbert »
Thank you Ciclo!!!!
thealbert
Post by thealbert »
With Vogtland spring
Inviato dal mio SM-A500FU utilizzando Tapatalk
thealbert
Post by thealbert »
Next up....
thealbert
Post by thealbert »
6C1857507C
6C1857502H
6R0959801BD
6R0859802BF
6R1959565GREH
https://youtu.be/Ae_sobuO6Uc
MichelKasapovic
Drives: Polo 1,2 tsi 90bhp 6r,6c
Post by MichelKasapovic »
Ebay MartinDK. Masser af forskellige slags. Koster næsten ingenting. Org. alu R Line eller GTI covers
thealbert
Post by thealbert »
New wheels
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
very nice polo.
door lights are nice mod.
why did you make it above and not at the bottom of the door?
cant make it clear from the images but does door lights dont sit flush?
thealbert
Post by thealbert »
I put them as the 4th golf series and are not thread-wise slightly
thealbert
Post by thealbert »
Hello, I need your help, sorry for my english I have fitted the front sensor kit but they only work when I put the reverse gear!
I miss to connect 2 wires of the button, I saw from the wiring diagram that the gray wire goes to pin 4 of the BMC!
The problem is that in my bmc at pin 4 there is nothing, how can I do?
ThanksImageImageImageImageImageImageImageImage
Inviato dal mio RNE-L21 utilizzando Tapatalk
On the other hand, I remember that I bought the PDC button that you show in the image to compare the surface color with the original :lol:, and that button does not have PIN 5, check it.
In such case, your PDC button is not correct and you must buy the original one.
BTW1, your BCM feeds the lighting of those buttons through Terminal T73b/1. (olds BCMs)
BTW2, Thank you very much for the images. (the images stimulate to help :mrgreen:)
