Re: My 2010 Polo
Posted: Mon Oct 05, 2015 10:00 pm
No don't get resistances unless you have a bulb error that doesn't go away with vcds
Probably the Worlds greatest Polo resource
https://uk-polos.net/
Thx iichel! Finally i found the guide: http://www.polo9n.info/Wissen/anleitung ... heckklappeiichel wrote:That would be the 1K8 827 761 C or 1K8 827 761 D (mostly the D is used in the Polo)
No problemAlexR wrote:I'm gonna go with the OEM leds.
Thanks for sharing that link CNK.
But it's a b***h to close right?CNK wrote:No problemAlexR wrote:I'm gonna go with the OEM leds.
It works:
The tailgate closes a little harderMart!n-GTI-DK wrote:But it's a b***h to close right?
After every couple of winters I've had to get new gas struts for all my cars (sure it's the same for most drivers) and I like to fit them myself (big woop, I know) but I've never had much luck with Googling. As a helpful tip for anyone in a similar boat, you can find the exact gas struts needed for your exact model using this search function. All you need to enter is your car's model, make and fuel and engine type to get a result. And if you fancy putting those bad boys on yourself but don't know where to start, Mick's Garage YouTube channel has this great instructional video.iichel wrote:you need a pair of gas struts of a Seat Toledo from 2000 (around that year) and a set of Scirocco puffers. The puffers need to be shortened a bit.
If you then hold the middle button of the remote for a few seconds, the boot pops open. And the tailgate opens all the way.
If you google a bit you'll find the part numbers for sure.
Thanks!VeeDubb wrote:After every couple of winters I've had to get new gas struts for all my cars (sure it's the same for most drivers) and I like to fit them myself (big woop, I know) but I've never had much luck with Googling. As a helpful tip for anyone in a similar boat, you can find the exact gas struts needed for your exact model using this search function. All you need to enter is your car's model, make and fuel and engine type to get a result. And if you fancy putting those bad boys on yourself but don't know where to start, Mick's Garage YouTube channel has this great instructional video.iichel wrote:you need a pair of gas struts of a Seat Toledo from 2000 (around that year) and a set of Scirocco puffers. The puffers need to be shortened a bit.
Cheers !
