Page 2 of 3
Re: RNS315 with bluetooth kit.
Posted: Fri Jan 22, 2016 4:50 pm
by Willni
yeah but the new microphone piece that was recommended seems a bit big if I removed a bit from the loom, expect for this part I'm all wired and ready to go just plugging it in is the hard but
Posted: Fri Jan 22, 2016 4:52 pm
by alexperkins
TPK of course has to come out if adding this microphone - thats the whole point. There'll be an inline loom that the TPK uses which has to come out
Can you post a pic of how the wiring on the rear of your unit and loom look
Posted: Fri Jan 22, 2016 5:01 pm
by Willni
http://imgur.com/a/yJLWt
This are hopefully the photos you need if not I can take more, I think the green is the TPK as it's label phone
Posted: Fri Jan 22, 2016 5:04 pm
by alexperkins
I would imagine you are taking the TPK out completely and just using the built in bluetooth? If so, remove the TPK entirely and the new microphone should plug in where the TPK was.
Posted: Fri Jan 22, 2016 5:07 pm
by Willni
How do I remove it from the loom? and I'm just going to hide it as it seems a lot of effort to completely remove it and it doesn't do much harm
Posted: Fri Jan 22, 2016 5:11 pm
by alexperkins
As you can see here:
The TPK kit uses an 'inline' add on loom. you need to find the other end, and unplug the car side quadlock from it, then plug that into the back of the radio directly with the new microphone plugged in
Posted: Fri Jan 22, 2016 5:15 pm
by Willni
so basically that's just an extension lead (I'm trying to dumb it down) and then I can remove that and I'll have another quadlock (the lock clip from the back of the radio) to hook up?
Posted: Fri Jan 22, 2016 5:31 pm
by Willni
Got most of it now Just a small blue wire and a small black one both very thin they go toward the steering wheel, ok it was the mic I think, but the new mic doesn't fit into the quadlock
Posted: Fri Jan 22, 2016 5:54 pm
by alexperkins
That'll be an ignition live and the microphone wire
What's the plug on the new microphone look like?
Posted: Fri Jan 22, 2016 6:03 pm
by Willni
Its in the pictures i put up, it was one from ebay that was recommended
Posted: Fri Jan 22, 2016 6:26 pm
by alexperkins
If it's the one I recommended that plugs into the back of the quad lock at the top right. Same position where the green plus was on the TPK loom
Posted: Fri Jan 22, 2016 6:53 pm
by Willni
Trimmed the plug so it would fit but get a buzzing if i make a phone call from the person i calleds end
Posted: Fri Jan 22, 2016 7:15 pm
by Willni
Nvm it was in upside down
by alexperkins
All good now?
Posted: Fri Jan 22, 2016 7:56 pm
by Willni
yep only thing I worry about is the lead coming out but I doubt that will happen
