6R 1.6 TDI Stage 2
Re: 6R 1.6 TDI Stage 2
With original BCM goes to work the buttons on the right side only but not the backlighting.
The right buttons (CCS) could work, but it is absolutely necessary to change the stalks. (tip: contact me by PM)
With new BCM https://c-a.d-cd.net/dc7c38as-960.jpg you get the backlight of buttons only...hmm... what is your current BCM?.
To FLA (HBA) the BCM 7E0 is mandatory, also in your case many modifications on the original wirings. viewtopic.php?f=56&t=58703&p=505011#p505010
Waldi
Drives: Polo 6R 1.6 TDI
Post by Waldi »
Today i got the new Airbag, 5G0 880 201 C with the wires. This weekend i will install the new steering wheel. I hope that a few buttons will work.
For all other questions (Private Message) I think everything is OK, but would have to look at the ETKA.
The problem is that I do not have time right now. I am extraordinarily busy at all times, every day ... :lol:
Waldi
Post by Waldi »
Yesterday i wired the two cables (Lin & +12V). The right buttons working now perfect, on the left side i can control the volume. Cruise control and lighting doesn't work.
In VCDS i selected the option "mfl on"
Is it possible to use the cruise control on the SW by changing wires on the T41?
The lighting will only work with a new bcm... I know. I think I will change it to a 7e0 like iichel and ciclo. Later I will install xenon or led headlights with the AFL ;-) we will see...
Special thanks to you ciclo and iichel!! Without your help I wouldn't do projects like this! It makes a lot of fun to do these things and it is amazing what some guys can do with the 6r!
By the way, ciclo, which drag force have you chosen for the steering wheel? I selected the "GTI-Steering" I think the drag force with the new steering wheel is higher than with the old one, okay the new SW is a little bit smaller... But... It feels good. With the other options you can move the SW too easyly in my opinion.
Waldi
Waldi wrote:"
It is highly probable.. :lol: but ...
You can see it in autoscan on pg 118 of my topic.
Sorry for my very short answers, honestly ... I not even have time to add smileys. :mrgreen:
