CNK's Polo 6R 2.0 Shadow Blue
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Re: CNK's Polo 6R 1.4
Be aware that it is a VERY Expensive mod to get the folding mirrors... It's around €550 in parts alone...
I thought about doing it myself. But I thought that €550 for just adding one extra feature to the mirrors (no matter how cool it is) was a little to steap a price...
- CNK
- Drives: 6R
Yes, I know that the new folding mirrors are expensive, so I would buy a used mirrors.Mart!n-GTI-DK wrote:Be aware that it is a VERY Expensive mod to get the folding mirrors... It's around €550 in parts alone...
I found 8 PIN VW Polo 6C 6R 5DV mirrors for 310 PLN apiece (its about 70 EUR / 78 USD / 54 GBP).
I think this is an acceptable price.
aren't mirrors 10-pin?
- CNK
- Drives: 6R
Why 10? Polo has mirrors 6 and 8 piniichel wrote:aren't mirrors 10-pin?
well i mean, you need:
1 GND
2 Turn signal
3 heater
4 adjustment motor up/down
5 adjustment motor left/right
6 potentiometer up/down
7 potentiometer left/right
8 fold motor to fold
9 fold motor to unfold
this is not the pin numbers correctly but a list of what you need
1 GND
2 Turn signal
3 heater
peter_dk25
- Drives: Blue GT
you got a PM!CNK wrote:peter_dk25 wrote:It is not the mirrors - but the window regulator motors which is different.So, if I understand, I need to buy any LHD mirrors (6R/6C), module K418 (like @ciclo: viewtopic.php?p=472068&sid=ce368af786d7 ... 5d#p472068) and switch 6R1959565 GREH? Is that all?iichel wrote:Yes, that's what I meant but failed to say. My bad
Is it better to buy window regulator motors instead module K418?
Window regulator motors:
6R0 959 801 BD Z0D
6R0 959 802 BF Z03
- CNK
- Drives: 6R
Big thanks again!peter_dk25 wrote:you got a PM!
6R at the beginning of production had two types of connectors (couplings) depending on the month of manufacture.
12-pin <--- November 2009 ---> 10-pin---> to the end.
No problem for this, you can swap the couplings and fixed the problem.
- CNK
- Drives: 6R
Yesterday I installed GSM antenna for premium bluetooth under upper A pillar trim piece.
This is impossible to install this like Golf 6:
because there is not enough space in Polo 6R, so I did it a little differently. I installed the antenna in a plastic cover:
I have used this antenna: http://www.carsystems.pl/gsm-antenna-fo ... id111.html
In this way it fits perfectly
- CNK
- Drives: 6R
I cleaned my first message
Today I ordered RVC and I'm waiting for new BCM 7E0 and rest of R-Line front bumper
It seems that is coming a Spring with many improvements for your 6R.
- CNK
- Drives: 6R
Yes, my Polo will be happyciclo wrote:It seems that is coming a Spring with many improvements for your 6R.
Today I received RVC (shipping was very fast, because it was shipped from Poland: carsystems.pl)
Very thanks for your tutorial: https://drive.google.com/file/d/0B2nv91 ... JUSlU/edit - certainly help me with retrofit
puff ... I would have to update that guide with better pictures.
Thanks to you for sharing your mods... if you need my help to install BCM 7E0 no problem, I would like to help you.
- CNK
- Drives: 6R
This 7E0 BCM will be ok?ciclo wrote:puff ... I would have to update that guide with better pictures.![]()
18.11.15, 0733 H80
I like your polo so much! i didn't expect this post comes from Poland, a remote mistery country for us!
i will view all your photos when i am back at home with my pad at hand~
