Page 2 of 2
Posted: Sat Aug 07, 2004 5:58 pm
by Neimad
jrw wrote:I've heard about loads of peeps having probs with the cd changers. I've got the in dash one and have had no probs with it. Is it the in-dash one you guys have?
Mine's the in-dash 6xCD changer unit, yeah.
Posted: Mon Aug 09, 2004 8:42 pm
by MintySE
my mum's car has the same prob on the drivers sid edo u think i should get her to get it replaced under warrenty ? she just thinks it's caus e she leaves the window ajar but i guess shesw wrong and we do wash the car with a low power jet wash
Matt
Posted: Mon Aug 09, 2004 9:08 pm
by Neimad
MintySE wrote:my mum's car has the same prob on the drivers sid edo u think i should get her to get it replaced under warrenty ? she just thinks it's caus e she leaves the window ajar but i guess shesw wrong and we do wash the car with a low power jet wash
Matt
First thing I'd do is make sure that the window is closed as tightly as it will go before you next wash it. If after doing this you still get water ingress, I'd take it to the dealer (especially since it's still under warranty).
Posted: Mon Aug 09, 2004 10:04 pm
by algenon_iii
Matt
It could well have something to do with the window being slightly ajar, as I used a pressure washer this weekend and had no problems. First I made sure the rear windows were wound up properly (which they were), so I suspect when I had the problem the window was open enough to let water in.
It could be the winder mech. is dodgy and the window winds it's self down slowly bit by bit (cousins octavia has a tendancy to do that).
Posted: Tue Aug 10, 2004 4:13 pm
by leonsmith
Yes. Changed once, needs changing again now. Can't be ar$ed until it goes in for a regular service. Fortunately I'm a radio listener so don't miss the CD much.
Posted: Wed Aug 11, 2004 1:37 pm
by carmadaaron
so u reckon the changer is less reliable than the single slot?
any 1 got the single slot?
thinking of getting 1
[/i]
Posted: Fri Aug 13, 2004 6:16 pm
by tim
i think i no what the problem is with the leaky windows; on work exp at a VW dealership we had a passat in wit same problem, the glass is held to the winder mechanism with two clamps at the bottom, it is possible for the glass to slip down between these, u just hav to loosen the clamps and pull the glass up a few mils and retighten, but y not let VW do it under waranty!!!!
