Looks like on the instruction for Golf VII there is mentioned pins B5 and B45 instead of B3 and B40 marked on my cable stickers.
Fog light retrofit
Re: Fog light retrofit
Great,
chisyelamos1
- Drives: 6c 1.4tdi
Re: RE: Re: Fog light retrofit
Yes.Jussu wrote:Great,![]()
we have to connect as the decals indicates the cables.
mk7 golf instructions are for what to do but with the numbers changed
Enviado desde mi LG-H815 mediante Tapatalk
chisyelamos1
- Drives: 6c 1.4tdi
Do not worry about translators (all are a joke). English people know perfectly well that the English and Spanish (castillian language) are built differently.chisyelamos1 wrote: [emoji12]
the translator sometimes jokes with me
Hehehe
Thanks for scheme
Will be very difficult that someday exists a good English-Spanish/Spanish-English translator. Curiously are the two most widely spoken languages on the planet earth.
Thanks to you for sharing your retrofitting of 6C fog lights.
Ah! I forgot, in the scheme have the solution for automatic lights. (AUT)chisyelamos1 wrote: Thanks for scheme
I remembered that we talked about it.
chisyelamos1
- Drives: 6c 1.4tdi
Re: RE: Re: RE: Re: Fog light retrofit
Yes, but i don't know what type of sensor i need. For exampleciclo wrote:Ah! I forgot, in the scheme have the solution for automatic lights. (AUT)chisyelamos1 wrote: Thanks for scheme
Or
And if i need change the bcm
For 6C is like the second model.
https://www.google.es/search?q=5Q095555 ... 66&bih=638
https://www.google.es/search?q=5Q095555 ... 5Q0955559B
https://www.google.es/search?q=5Q095554 ... 66&bih=638
https://www.google.es/search?q=5Q095554 ... 5Q0955547B
Autoscan? to know your BCM model.
chisyelamos1
- Drives: 6c 1.4tdi
There things to fail in this versiónciclo wrote:For 6C is like the second model.
Paste It
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
http://www.Ross-Tech.com
VIN: W License Plate:
Mileage: 28884km-17947mi Repair Order:
Chassis Type: 6R (6C0)
Scan: 03 09 10 15 16 17 19 44
VIN: WV Mileage: 28884km-17947miles
16-Steering wheel -- Status: Cannot be reached 0100
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 G HW: 6R0 907 379 BA
Component: ESP9.0i H03 0003
Serial number: 08510046141103
Coding: 21DD2885892333C0091B106D005A841491CC90080007C9098F00
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 336287E39A26CFA690-8066
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 6C0 937 087 B HW: 6C0 937 087
Component: BCM PQ26 Me4R H07 0065
Serial number: 009728000188
Coding: 000008404253005B4B844000400783480600590251010000000000000000
ASAM Dataset: EV_BCMA0 004008
ROD: EV_BCMA0_SE25.rod
VCID: 2D56919B7C029956C6-8078
Subsystem 1 - Part No SW: 6R0 959 801 AT HW: 6R0 959 801 AT Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU031101443045600
Coding: 0400A0
Subsystem 2 - Part No SW: 6R0 959 802 BE HW: 6R0 959 802 BE Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU031101443040540
Coding: 1400A0
Subsystem 3 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8611
Serial number: KU0KU003111443075954
Coding: 0400A0
Subsystem 4 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8611
Serial number: KU0KU029101443020382
Coding: 1400A0
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39331428807953
Coding: 0011051001
ASAM Dataset: EV_EPHVA18AU3700000 002024
ROD: EV_EPHVA18AU3700000_AU37.rod
VCID: 3D76A1DBAC6209D676-8068
Address 15: Airbags (J234) Labels: 6C0-959-655.clb
Part No SW: 6C0 959 655 A HW: 6C0 959 655 A
Component: VW20Airbag01B 001 0330
Revision: -------- Serial number: 003LM006AMJH
Coding: 88C0C000000000005C0000CA000800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X_SE25.rod
VCID: 316E8DEB603AFDB6E2-8064
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 410 820 909 14
Component: SideSensor_Df 151 0800
Serial number: 3575H00A11627B605246
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 2 - Part No SW: ----------- HW: 410 820 909 14
Component: SideSensor_Pf 151 0800
Serial number: 3585H00B515DADC412A$
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 3 - Part No SW: ----------- HW: 442 150 111 14
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00BD175112701F4
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 4 - Part No SW: ----------- HW: 442 150 111 14
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00B71751125B32/
Coding: 2D2D2D
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 6C0 920 731 A HW: 6C0 920 731 A
Component: KOMBI 110 0290
Coding: 07A5090021000008000828000000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009040
ROD: EV_DashBoardVDDMQBAB_VW26.rod
VCID: 204878AF3BD0443E7D-8074
1 Fault Found:
16777024 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 4
Reset counter: 43
Mileage: 27313 km
Date: 2016.09.16
Time: 19:33:16
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6C0 909 901 HW: 6C0 937 087
Component: GW MQB A0 H07 0065
Revision: -------- Serial number: 009728000188
Coding: 030000045F0A590071000000000000010001010000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_SE26.rod
VCID: 65C629BB64726116CE-8030
Subsystem 1 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 51297322042821959258
5 Faults Found:
131587 - No Communications with Undefined Control Module
U1126 00 [009] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 14322 km
Date: 2016.03.16
Time: 18:45:50
131590 - No Communications with Undefined Control Module
U1126 00 [009] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 14322 km
Date: 2016.03.16
Time: 18:45:50
131596 - Steering Column Control Module
U0212 00 [009] - No Communications
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 14322 km
Date: 2016.03.16
Time: 18:45:50
131619 - Control module for rear lid electronics
U1047 00 [009] - No communication
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 14322 km
Date: 2016.03.16
Time: 18:45:50
131654 - No Communications with HVAC Control Module (J301)
U0164 00 [008] - -
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 28747 km
Date: 2016.10.09
Time: 12:50:52
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 M HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3211
Serial number: PEBJ0449
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_VW26.rod
VCID: 326C82E7653CC6AE9B-8066
End-------------------------(Elapsed Time: 01:57)--------------------------
If you see something, please, let me know (faults)
Thanks for sharing the autoscan.
T73a/43 is present in your BCM but I do not know if the automatic lights are possible with that BCM software.
No information online about it. (i mean other autoscans)
As for faults and coding of this BCM PQ26 will have to search online, this BCM model is unknown to me.
chisyelamos1
- Drives: 6c 1.4tdi
Thanks!ciclo wrote:Thanks for sharing the autoscan.
My bcm are "the ugly duckling" hehehe
when I go to buy the pieces, I'll investigate. At least I would if I put that mirror work good, then I'll set correctly
Great, thanks for the help!
There is lot´s of knowledge around here
I have connected the wires according to this diagram.
However there is no current coming to the B3 or B40 wires when try to put the front fog lights on. Rear fog light works still normally when testing that.
Could it be problem with BCM version or BCM software? (BCM PQ26 Hi4R H08 0086)
Fuse problem?
I have enabled light switch with front fogs on VCDS.
Part No SW: 6C0 937 089 C HW: 6C0 937 089
Hmm...maybe you must extract from the light switch knob (new light switch, with light for front fog) twice.
1st -- rear fog.
2nd -- rear and front fog.
It may be the problem but does not have to be your problem.
VCDS faults?
1st -- rear fog.
VCDS faults?
I have new light switch with two "steps"ciclo wrote:Part No SW: 6C0 937 089 C HW: 6C0 937 089
1st -- rear fog.
It may be the problem but does not have to be your problem.![]()
VCDS faults?
I have enabled the front fog lights from VCDS but was there some adaptation also needed to be done from VCDS?
Yes, maybe this info is useful for you.
(As for light switch, you know that I was joking, however I've seen worse things...
I hope you understand me
