Polo 6R Scan Help
Re: Polo 6R Scan Help
I dont want to be offensive, not at all. But sometimes I do struggle a lot to understand what you mean. Just so you know. I'm more than happy to help out.
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
In blocks measuring shifter wiper work
For the cruise control has no cables. I have to buy.
Rain Sensor does not work
The navigation are two antenna cables white and one blue GPS which is inserted, the board of the receiver.
I have a rearview mirror with a sensor.
Are they ready to beam sensru rain?
Can it be so with the shifter cruise control does not work that wipers are also not working?
With the wipers in position one, it's set to automatic. This means they only work when the rain sensor detects rain. The rain sensor then determines how fast the wipers will go.
According to your auto scan the rls is connected.
You do need a wiring for the cruise control. There is a big topic here with a lot of information on cruise control retrofitting
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
When you disconnect the rain sensor wipers then first gear will work?
No it's a setting im vcds. Byte 14 bit 7 I think in the bcm
Valgas6R, It is recommended that you take pictures of everything (connectors, wires, dashboard, exterior).
Please can you take a picture like this?
Maybe the problem is in other ground wire. (point)
Valgas6R. Copy and paste new codings from here.
BCM (Cent. Elect)
new coding
25B02BBF08E1250093300E916CAB0FD05AC0672F60051041200000010000
RLS (Rain Light sensor) drop-down panel in BCM
new coding
06302D
Clear all DTCs
Post a new Autoscan.
The radio antenna fault is normal because you have installed a shark model without FM/AM reception. Your Radio works due to have installed the Diversity system. (2nd antenna in rear window)
... and please show us pictures of your 6R. Example from a Polish friend and an excellent user of this forum.
Your 6R :?:
Image :lol:
Valgas6R wrote:im the boss i cut off power and now me rnse510 wanna code :) i dont have code yeeee ;//////////////// this is a joke
The one that sold you the car has it. :evil:
VW dealers can also provide, upon payment. (diagnostic process)
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
Where u find that xDDD? yep this is me polo :) i back work 16:00 and i go make all u say :)
In a hidden page indexed by googlebot for google cache memory. There are five more pics but are missing some data...
It's a beautiful 6R 8) , but... why the front bumper is not R-line model?
PS... and do not worry about your English, I can understand your English because I learned my current basic English with this song. :lol: (just kidding, or maybe not)
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
here is a scan http://textuploader.com/dajll after celar and new scan
cant add this code http://ifotos.pl/zobacz/FAILEDjpg_arhqrhn.jpg
front bumper was replaced because the car was lightly hit in the left fender and bumper. I've seen pictures. It was not that bad . Horn bumper just fell off. Everything fits perfectly
so you might want to play a bit with the ignition to make the RLS coding work. it's not uncommon to not work directly. igintion on/off/cycle it a few times helps.
try this code for the bcm, it might take away the errors for the alarm horn and the anti-theft sensor:
25B02BBF08E1250001300E916CAB0FD05AC0672F60051041200000010000
Ok, in RLS unmark Byte0 Bit5
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
So I have not after a successful encoding. Turn off the ignition and turn and try again.
Edid: Ciclo. I tried to do so too.
The same error
Edit 2
How to do that windows were leaving the key
The problem is that the BCM coding was a disaster, and as also had/has problems with the wires, we do not know exactly the units they are installed in your car.
For example, it does not have sunroof but was coded for it.
Please specify with images, pr codes, etc... or let us know if your 6R has factory alarm. (Antitheft system with interior sensors near to dome lights)
VCDS only reads what is possible if the wires, codings, and units are in a minimun condition.
Once the faults are solved, we can talk about all that can be coded in your 6R to have more features. :wink:
Edit:
I have the impression that you have not read owner's manual. :lol:
