Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
benzinkopf
Drives: 1.2TSI 105HP DSG7
Re: Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
Post by benzinkopf »
Yes. Exactly.
Mine is 4X1, 4UE, 9P3.
So I guess 4UF is Airbag for Driver/Front Pax with deactivation.
Thanks Ciclo. Will be recording this.
benzinkopf
One good thing with "retrofitting": reuse the old part for something else[emoji23]
benzinkopf
Hi everybody,
Is this possible? Is there any power issue to power up both LEDs in the button? any other thing that i should take into account? Appreciate your feedback. Tq.
I guess it can then only either lock or unlock
benzinkopf
Oh yes iichel. I forgot that the lock switch does have two "Switches" for lock/unlock.
so if i use heated seat regulator, i only have 1 switch. hurm
Good headup iichel! thanks for that.
You could use one switch to lock and one to unlock. How much sense it makes is up to you to decide... :mrgreen:
benzinkopf
Hehe. Actually, the best option is to do like Ciclo, means another button on the passenger side. But i just want to make the job easier rather than laying out wiring through the door.
it looks more complicated than it is. you can do it.
How to install 7E0 BCM in your 6R:
Preview image. 16 pages
Download or watch here. 8)
benzinkopf
[emoji41] I'm going to be electrified soon. So i change my name to elektrokopf for awhile! [emoji12]
Image Image... Sorry!
Download or watch the pdf document again from the same link. Already corrected.
benzinkopf
Noted Ciclo! Thnx
benzinkopf
My next mod is ready. Thinking of the right way to wire this. Image
benzinkopf wrote: Thinking of the right way to wire this.
Check your email. :wink:
benzinkopf
[emoji1360][emoji2]
Btw. If i splice the power from existing U1 front (which i have another permanent charger) should i increase the 15A fuse sb42?
