☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼
Re: ☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. Light Assist. ☼
antardaksh04 wrote: Hi Fernando...
OK. I subscribed to the indicated topic. :wink:
Danger Boy
Drives: 6R SEL
Post by Danger Boy »
Hi Ciclo, i am interested in the auto headlghts for my polo 6r.
I am unable to private message you due to only registering now, so can you please private message me?
Thanks and i look forward to hearing from you,
Hi Danger Boy.
Please, first I need a little more information about your 6R.
...with Bixenon from factory?
...with rain sensor?
or
...is it Bluemotion with rain sensor?
With a VCDS autoscan everything would be infinitely more easy. Requested information.
Danger Boy
Drives: 6R SEL
My polo 6r is a 2010-11 model 1.4 SEL.
I have fitted aftermarket HID's.
I Don't think it has a rain sensor.
Ok, thank you very much for your reply Danger Boy.
Do you have VCDS?
Please read the first post of this sale, this way you will know if your 6R has RLS. (Rain Light Sensor)
Thanks.
Danger Boy
Drives: 6R SEL
Unfortunately I don't have VCDS. Can we discuss this further on PM?
Thanks.
Check your inbox.
hmthakur
Drives: Polo gt tsi 1.2 dsg
Post by hmthakur »
Hi buddy ordered bcm max 7e want the wiring but for time being i am not changing headlights keeping halogen headlights which wire loom will i need??
hmthakur
Post by hmthakur »
hi gone through graaja's topic about h7 to bixenon. can we keep the cornering light in the fog lamps active as well as with cornering headlights?? as i want both cornering headlights and cornering foglights active at the same time
graaja
Drives: Polo GT TSi
Post by graaja »
hmthakur wrote:hi gone through graaja's topic about h7 to bixenon. can we keep the cornering light in the fog lamps active as well as with cornering headlights?? as i want both cornering headlights and cornering foglights active at the same time
I think this is not possible - I will let ciclo confirm it. As the cornering lights are directly controlled by the BCM, the BCM's output driver may not have the capacity to drive two lights in parallel. This may even damage the BCM.
Hmm ...(yes and not) so NO. ...besides, it doesn't make sense, you can install better bulbs on one place.
Connect the lights so a BCM Max control them is more than the simple functioning of lights (diagnosis, adaptation, coding, etc).
My wiring only for original parts and in the right way. I don't give support for other 'inventions' Image, or recurring ideas (with my deep respect for it).
:arrow: viewtopic.php?f=62&t=69223#p516196 Please read red, ...there is always a better place to answer a question with a better answer. :lol:
graaja wrote: ... As the cornering lights are directly controlled by the BCM, the BCM's output driver may not have the capacity to drive two lights in parallel. This may even damage the BCM.
A perfect answer. Thank you. 8)
hmthakur
Post by hmthakur »
hi fernando
can you confirm if ccs stalk sold by you to me model no 6r0953 507 B can be used for high bean assist??
hmthakur wrote:hi fernando
:arrow: If you mean these stalks sold in 2015 and they worked perfectly since then ... logically NO. CLICK HERE
HBA system was possible later, thanks to a crazy people who share the information for free.
again :arrow: viewtopic.php?f=62&t=69223#p516196
Tuli82
Drives: VW Polo 6R
Post by Tuli82 »
Hi Fernando,
Do you still sell this wiring loom?
I would love to buy a set for my polo 2014 (bixenon and rain sensor from factory). I can provide autoscan later on (if you need that).
Could you please send me PM with some confirmation?:)
Thanks, Pavol
