Upgrade to BCM Max with RLS and auto headlight (Dual beam H7)
Re: Upgrade to BCM Max with RLS and auto headlight (Dual beam H7)
I can provide you these parts, no problem, but in this case this great topic that you have opened has no sense. :roll: ... :)
It also makes no sense to me to send you almost all the parts without manufacture the wiring (this part of the wiring). You already know that you also need the BCM adaptation wiring (+ installation guide, + coding ).
However and this is important to me, I respect and applaud the will to make it yourself. 8) You must wait, because right now I am waiting to receive a great order that I made for all this type of parts.
What do you think?
antardaksh04
Drives: TSI
Post by antardaksh04 »
Hi Fernando,
Thanks, I will wait, the only reason I wanted to take your help with the parts was because some parts are available easily like relay, terminals but others like relay bridge, relay holder and the 2/10 pin connectors are hard to find.
It would be great if you can help me with the parts once you get your order delivered.
I am completing installation of 8K OPS , so will be able to complete that till I receive parts for auto headlight.
Regards.
Do not worry I will help you, you can be sure of it.
The OPS is an important safety system apart from other things (aid to driving), good choice 8), it is a necessary equipment without a doubt, at least in the rear side for small cars (3K-4K), and 8K the rest.
Highly recommended even if a non-original OPS is installed (on Old cars).
graaja
Drives: Polo GT TSi
Post by graaja »
antardaksh04 wrote: I am completing installation of 8K OPS , so will be able to complete that till I receive parts for auto headlight.
Regards.
Hi, Can you share some details on the 8K OPS installation - like part numbers, source, reference links with details on installation etc.?
I am thinking about at least a rear OPS installation as our Polo 6R in India comes with just audio feedback and no CAN bus connection.
patil
Post by patil »
Hi all..
Even I am preparing to install 8k ops on my 6R.
I have procured all the necessary parts and harnesses.
Just not getting enough time. Too hot outside :mrgreen:
I can share the details of aliexpress seller who can send all parts together at a reasonable price.
graaja
Drives: Polo GT TSi
Post by graaja »
patil wrote:Hi all..
Hi, Can you please share details of where you got the parts? I am still thinking if I should do a simple 4K, or a full 8K.
antardaksh04
Drives: TSI
Hi graaja,
Wiring and 4 sensors
https://www.aliexpress.com/item/VW-NEW- ... 0.0.erSlED
8K OPS module
https://www.aliexpress.com/item/VW-POLO ... 0.0.erSlED
Switch (spaider-fors)
https://www.drive2.com/o/b/467968092773810958/
Installation (firegrafik)
https://www.drive2.com/l/452708245769815793/
Regards.
antardaksh04
Drives: TSI
Hi Fernando,
I checked with Mr Heiko and he has most of the terminals, could you please check this list of connectors and terminals required for auto headlight wiring.
I verified this from the ETKA connector catalog.
10 Pin connector male 1J0 972 785
10 Pin connector female 1J0 972 775
10 Pin connector female terminal 000 979 228
2 Pin housing female 1J0 972 752
2 Pin housing Male 1J0 972 762
2 Pin connector femal terminal 000 979 226
6/4 Pin Housing 4H0 937 529 ( 2 Type pin's ) 4H0 937 529
6x Pin PT 2,8mm Female
and 4x Pin MCP 6,3mm pics
2 Pin PT in 2,8 20x(JPT)
2 Pin PT in 4,8 20x (SPT)
Regards.
antardaksh04 wrote:Hi Fernando,
2 Pin connector femal terminal 000 979 226 ---> 000 979 228
:?: 2 Pin PT in 2,8 20x(JPT)
:?: 2 Pin PT in 4,8 20x(SPT)
Regards.
But you're going to spend more money than if I make the wiring for automatic lights for you (this part of the wiring). You already know that you also need the BCM adaptation wiring.
Wait, I'm going to take a picture of a wiring for automatic lights...tic,tac,tic,tac...here goes:
Full, with relays + bridge (+ plastic ties). Tell me what you think by private message, and I tell you the price.
...and do not worry if you've already talked to Mr. Heiko, I buy many of terminals from him, so it's the same.
antardaksh04
Drives: TSI
Hi Fernando,
Could you please check if source and target connections are listed correctly for the BCM adaptation wiring that will connect to WL4 (Auto headlight) wiring
Regards.
The pin assignments shown in this table for your VW Vento are correct for your requeriments. (7E0 BCM)
How to install 7E0937090 BCM Max in 2016 VW Vento RHD non Bluemotion. Halogen headlights. (antardaksh04)
:arrow: Follow this guide for proper installation. :wink:
antardaksh04
Drives: TSI
I have some update (off topic)
I completed installation of 8K OPS and wiring for DRL (beside foglight). Here are some pictures from the install.
DRL will work after I connect 2 wires to BCM and complete wiring for auto headlights.
Video captured while testing
Next would be installation of wiring that I got from ciclo for automatic headlights.
Regards.
graaja
Drives: Polo GT TSi
Post by graaja »
Awesome installation antardaksh04. This is an essential upgrade!
Good job! 8)
You already know that you can contact me by email if you need my help to install the BCM adaptation wiring and automatic lights. :wink:
