Polo 6R 2016 Mod.
Re: Polo 6R 2016 Mod.
rdasadia wrote:
iichel wrote:The 7E0 937 090B will not always support the LED headlights from Polo 6C
So you suggesting to to put the bixenon lights?
Did you inform about it before buying the BCM? (LED or Bixenon)
rdasadia
Drives: Polo GT 1.2TSI DSG 6R 2016
Post by rdasadia »
I was always planning for installing LED front lights & took for granted that 7E0 937 090B will support it.
rdasadia
Post by rdasadia »
ciclo wrote:There are no suggestions because it is not possible.... impossible there is nothing, but I do not think you want to make a big mod to your 6R ... engine, ABS unit, etc, etc...
A new car is better option.
MFSW?
MFSW?
MFSW?
Ok so I used ODIS and changed the coding for subsystem 1 RLS to A4FFFF and then I tried to change the same coding for Subsystem 4 RLS. It accepted but now when I scan from VCDS subsystem 1 is showing new coding but subsystem 4 is showing the old coding. Below is the new scan using VCDS.
Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 271115 03  37  0059
   Coding: A4FFFF
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  020 2551
   Serial number: 13102848151112221545
   Coding: 050008
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  020 2551
   Serial number: 13202849151112235703
   Coding: 050008
   Subsystem 4 - Part No SW: 13 202 849 15    HW: 132 028 491 51
   Component: RLS 271115 03  37  1122
   Serial number: ÿ132028491511122357
   Coding: 353730
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  019 1552
   Serial number: 13202728151109234823
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  019 1552
   Serial number: 13202729151110091329
   Coding: 020000
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
Not any 7E0 BCM supports LED headlights. I had faced with that issue. As I found out the issue is in EEPROM preset in the firmware of the BCM. At first I took 7E0937090 for Russian Polo Sedans. But because of Polo in Russia comes only with halogen or bixenon headlights, so BCM doesn't have EEPROM configuration for LED headlights, so it hadn't worked properly. But problem was only with DRL. In parking-light mode it got off instead of to dimming.
I bought another BCM 7E0937090 from T6 Multivan, and LED headlights started work perfectly.
https://www.drive2.ru/l/458022735222719315/
MFSW?
MFSW?
MFSW?
   Coding: A4FFFF
   Coding: 050008
   Coding: 050008
   Coding: 353730
   Coding: 020000
   Coding: 020000
¿Why you change the coding of the Subsystem 1? Who told you to do such an awful thing? :evil:
Leave the RLS coding as it was previously.
The problem with your multifunction steering wheel is that you have installed an airbag wiring that is modified. Subsystem 4.
rdasadia
Post by rdasadia »
MFSW?
MFSW?
MFSW?
   Coding: A4FFFF
   Coding: 050008
   Coding: 050008
   Coding: 353730
   Coding: 020000
   Coding: 020000
Ok changing back to old coding. But I am unable to change the coding of subsystem 4 niether by vcds nor by odis.
rdasadia
Post by rdasadia »
Done. Error Free!! :)
What Next?
Friday,14,April,2017,21:08:16:58997
VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4334.4
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: MEXA16604GT072590   License Plate: 2099
Mileage: 10380km-6449mi   Repair Order:
Chassis Type: 60 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 65 0B
VIN: MEXA16604GT072590   Mileage: 10380km-6449miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number: 00000000000000
   Coding: 00250056232400080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6D9229D8BC778B2932-8038
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6501
   Revision: 00043014    Serial number: CU501511017434
   Coding: 0000020
   Shop #: WSC 01324 785 00200
   VCID: 3A38D28475B9EC91E7-806E
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 BH    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2463422A03C2461924724251C0800908
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0542717884C75369DA-8050
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Serial number: 05061504651234
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EB01E94E11100B19B-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 41CAA568D86FBF49A6-8014
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 352161294
   Coding: 3AB02BF848B30000013800007F6B9E9000C0600F608C0000200000000000
   Shop #: WSC 51200 002 104857
   VCID: 2A18E2C445195C1197-807E
   Coding: 0368DD
   Coding: 050008
   Coding: 050008
   Coding: 353730
   Coding: 020000
   Coding: 020000
2 Faults Found:
01516 - Terminal 30; Left
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 10384 km
                    Time Indication: 0
                    Date: 2017.04.14
                    Time: 01:58:04
00927 - Terminal 30 (Right)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 10384 km
                    Time Indication: 0
                    Date: 2017.04.14
                    Time: 01:58:04
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 J    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0105
   Revision: --------    Serial number: 28261224902578
   Coding: 300101
   Shop #: WSC 02756 790 50316
   ROD: EV_EPHVA18VW250GPCS.rod
   VCID: 393ACD88B8BFE789EE-806C
   Revision: --------    Serial number: 003GW012EG31
   Coding: 003036
   VCID: 49DABD48E85F77097E-801C
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H05 0805
   Coding: 140E01
   Shop #: WSC 12345 123 12345
   VCID: 47DEBB70FE4B817968-8012
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002300
   VCID: 689C58CC9B95AE0141-803C
   Component: IMMO          H05 0805
   VCID: 6A9822C48D999C1157-803E
Address 44: Steering Assist (J500)       Labels: 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014_VW12.rod
   VCID: 41CAA568D06FBF49A6-8014
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187     HW: 6RF 035 187
   Component: Radio         013 0116
   Revision: --------    Serial number: VWZGZ1R3521196
   Coding: 0000040000000F
   VCID: 06407674B1C15871D3-8052
   Serial number: 30000000054715
   ROD: EV_RDKBERU30_VW51.rod
   VCID: 373ECBB08EABF1F918-8062
End----------(Elapsed Time: 01:44, VBatt start/end: 13.6V/13.5V)-----------
Logically my friend. You have to install a correct airbag wiring (7E0 971 584) for your MFSW.
OEM, without weird modifications. :evil:
rdasadia
Post by rdasadia »
ciclo wrote:Logically my friend. You have to install a correct airbag wiring (7E0 971 584) for your MFSW.
Cool ..show me the direction :arrow: & will find my way 8)
Enter this BCM coding (copy-paste)
3AB02BBF48B30000013800107C299E9000C0414F608C0000200000000000
New Autoscan with faults. (logically)
Tell us the results (reverse light).
rdasadia
Post by rdasadia »
ciclo wrote:Enter this BCM coding (copy-paste)
New Autoscan with new BCM code. Reverse light still off.
Saturday,15,April,2017,12:06:49:58997
VCDS Version: 17.3.1.0 (x64)  HEX-NET CB: 0.4336.4
Data version: 20170320 DS270.2
www.Ross-Tech.com
VIN: MEXA16604GT072590   License Plate: 2099NEWBCMCODE
   VCID: 6D9229D8BC778B2846-8038
   Coding: 0000020
   VCID: 3A38D28475B9EC9093-806E
   VCID: 0542717884C75368AE-8050
   Coding: 01
   ROD: EV_LWSKLOVW25X_VW25.rod
   VCID: 7EB01E94E11100B0EF-802A
   Revision: V0000000
   VCID: 41CAA568D86FBF48D2-8014
   Coding: 3AB02BBF48B30000013800107C299E9000C0414F608C0000200000000000
   VCID: 2A18E2C445195C10E3-807E
   Coding: 0368DD
   Coding: 050008
   Coding: 050008
   Coding: 353730
   Coding: 020000
   Coding: 020000
4 Faults Found:
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 35
                    Mileage: 10389 km
                    Time Indication: 0
                    Date: 2017.04.15
                    Time: 12:02:39
03432 - Activation of Right Parking Light
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 35
                    Mileage: 10389 km
                    Time Indication: 0
                    Date: 2017.04.15
                    Time: 12:02:39
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 35
                    Mileage: 10389 km
                    Time Indication: 0
                    Date: 2017.04.15
                    Time: 12:00:59
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 35
                    Mileage: 10389 km
                    Time Indication: 0
                    Date: 2017.04.15
                    Time: 12:00:59
   Coding: 300101
   VCID: 393ACD88B8BFE7889A-806C
   Coding: 003036
   VCID: 49DABD48E85F77080A-801C
   Coding: 140E01
   VCID: 47DEBB70FE4B81781C-8012
   Revision: B9081001
   Coding: 002300
   VCID: 689C58CC9B95AE0035-803C
   VCID: 6A9822C48D999C1023-803E
   VCID: 41CAA568D06FBF48D2-8014
   VCID: 06407674B1C15870A7-8052
   ROD: EV_RDKBERU30.rod
   VCID: 373ECBB08EABF1F86C-8062
End----------(Elapsed Time: 01:43, VBatt start/end: 13.6V/13.7V)-----------
Excellent! Thanks.
This autoscan that you have shown us is more important because of what it does not say than by what it says ... 8)
The reverse light will work when you install the new wiring. These new BCMs Max have some different operations -internally- than the previous ones.
BTW, did you do this?
ciclo wrote: Connect your RDKS unit to the CAN lines of powertrain and tell us the results.
Do it as soon as possible. (Before I send you the new wiring)
Maybe we can improve your CAN-lines if you show me pics of this installation. :wink:
and...
The more information you provide the better the wiring. (I'm not a fortune teller yet :))
For example, images from connections of these headlamps that you currently have installed (guide installation :?:).
firegrafik
You should provide power supply 30 terminal to have reverse light working. Max BCM takes power supply for reverse light not from T73b/11 like lower BCMs, but from headlights power supply T73a/63 and T73b/68
Exactly.
rdasadia
Post by rdasadia »
ciclo wrote:Excellent! Thanks.
and...
Yes the TPMS is now connected to powertrain line thats why if you see the last two autoscan the error from TPMS and CAN of no communication has disappered as compared to the scan in my first post.
I will try to get more information of what you have asked
