Pave´s 2011 Polo 6R 1.2TSI 105HP Highline DSG
Re: Pave´s 2011 Polo 6R 1.2TSI 105HP Highline DSG
Yes, check your email.
Little more modifications since last post...
Got windows lightly tinted... pictures coming
Started to install BCM Max and OEM Xenon headlights... let´s see when those are finished
Updating pictures from that procedure later too
BCM coding sent....
Here is few quick (and not good at all
) pictures of new mods and what I have done last few days...
Better pictures will come later
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 073170389
Coding: 24B02BBF08A10000003004917C2B15D05AC0472F600510C0200000030000
Shop #: WSC 12345 123 12345
VCID: 2A501830454A131197-807E
... and bixenon headlights OK!!
viewtopic.php?f=56&t=69826#p520855
Monday,05,June,2017,20:02:21:46394
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWZZZ6RZBY142712 License Plate:
Mileage: 84390km-52437mi Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 0B
VIN: WVWZZZ6RZBY142712 Mileage: 84390km-52437miles
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 E HW: 03F 906 070 D
Component: SIMOS10.20H02 9856
Revision: -------- Serial number:
Coding: 002500D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070E 003013
ROD: EV_ECM12TFS_003_VW25.rod
VCID: 244CF6082F6EC561AD-8070
Readiness: 0010 0001
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3417100B4842C14E382D300401300
VCID: 06088C80B5921771D3-8052
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 387432788BE6B18111-806C
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU012.10.1010856
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU022.10.1012388
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU027.10.1012758
Coding: 08BC32
Subsystem 4 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU014.10.1011471
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 B HW: 7E0 919 475
Component: PARKHILFE 4K H10 0012
Revision: -------- Serial number: 12831028801597
Coding: 108101
ROD: EV_VW250ParkiAssis2.rod
VCID: 3D7A236CACC494A9C2-8068
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag01M H09 0020
Revision: -------- Serial number: 003GX009NX3Y
Coding: 00314D
VCID: 4A9078B0ED0A331177-801E
Serial number: 3575HRB405N085G248T7
Serial number: 3585HRB405P085G2AP9D
Serial number: 3515RRB405B036N2A8P4
Serial number: 3525RRB405B036N2H16T
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 860 F HW: 6R0 920 860 F
Component: KOMBI H04 0304
Coding: 140E00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 377631448EF8BEF918-8062
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002200
VCID: 68D4A2389BC6E10141-803C
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H04 0304
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6AD0D8308DCAD31157-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11220
Shop #: WSC 00788
VCID: 2F660924EAA8763940-807A
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: RCD310 EU T H06 5007
Revision: -----10S Serial number: VWZ4Z2P1327206
Coding: 05000400020001
Shop #: WSC 02754 790 12345
VCID: 336E0554928052D924-8066
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 6
Reset counter: 1
Mileage: 83087 km
Time Indication: 0
Date: 2011.09.22
Time: 13:29:21
End-------------------------(Elapsed Time: 02:46)--------------------------
... and everyone knows to whom all thanks will go
Some pictures of what I was doing last days...
Some polishing and coating...
Tiny steps towards Auto-levelling system (AFS)
Rear badge modifying...
Further modification for rims... removing vinyl wrappings and replaced with gunmetal rubber coating...
Maybe pictures are now working...
Yes, now they work.
Changed foglights to those with black surrounds and housing and without place for drl (6R0941061F, 6R0941062F) .... because drl´s are now somewehere else
New one on left, old one on right
that picture also doesn't work
Source of the pictures is same as all other pictures.... I can´t use these things...
I think it´s something to do if I make collection of pictures what I want to update...
Sorry... try to fix that
spacewalker
- Drives: Just a VW
just to want to see your new cluster , but cant ;(
Updated full auto scan to first page.... especially fo ciclo!
Here is some new mods:
Gti cluster finally
Last parts of the AFS
Newer version of pedal caps and now also footrest
Gti cluster finally
Now it is there... I hope
Big thanks to you again for making to have that new cluster possible!!
I think my phone died and there are more pictures... will upload more when I can.
