Retrofit Steering with Paddles to Polo 1.6 (Aisin GB)
bladekiller
Drives: 1.6 MPI
Re: Retrofit Steering with Paddles to Polo 1.6 (Aisin GB)
Post by bladekiller »
ciclo wrote: Tue May 16, 2017 11:05 am Welcome,
VCDS autoscan (full), and steering wheel image installed and running.
bladekiller wrote: Upon checking the TCM, I note that pin 13 & 19 is empty. Based on research from the web, these 2 pins should be relevant for paddles to work.
My question is, where do these 2 pins connect to? And what coding is appropriate for this?
Link me to this information. Thanks
Hi ciclo, the fullscan is below. Apologies for the delay.
Sunday,01,April,2018,19:49:08:52609
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: x   License Plate:
Chassis Type: 60-VW25 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 44
VIN: x   Mileage: 53330km-33137miles
Address 01: Engine (J623-CLSA)       Labels: None
   Part No SW: 03C 906 014 EK    HW: 03C 906 014
   Component: CLSA-MM7GV-G  H02 CLSA-MM7GV-G  H02 69176917
   Revision: --H02---    Serial number:
   Coding: 001A0014032400080000
   Shop #: WSC 83300 833 00005
   VCID: 6ADBBE7286B26814A6-5140
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 02: Auto Trans        Labels: 09G-927-750.clb
   Part No SW: 09G 927 750 LK    HW: 09G 927 750 LK
   Component: AQ 250 6F           2601
   Revision: 00H98000    Serial number:
   Coding: 0008520
   VCID: 0501EDCE4FECA76C2B-5140
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 6R0 907 379 BF    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0001
   Serial number: --------------
   Coding: 60DD2763412318C00617E471825718000000
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 0305F3D68AD8995C05-8056
   Part No SW: 6R0 907 044 P    HW: 6R0 907 044 P
   Component: Climatronic   H12 0614
   Revision: V0000000
   VCID: 408F3CDAD34E424458-8014
   Part No SW: 6R0 937 087 R    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H34 0424
   Revision: BF034001    Serial number: 0681 196142369
   Coding: 3BB02BBF08A10000003800003C2B1C9000C0414F60040000200000000000
   Shop #: WSC 83300 833 00011
   VCID: 4C9718EAEF069624B4-8018
   Subsystem 1 - Part No SW: 6R0 959 802 AL    HW: 6R0 959 802 AL  Labels: 6R0-959-802.CLB
   Component: -------------  006 5560
   Serial number: 13102576140604204658
   Coding: 010000
   Subsystem 2 - Part No SW: 6R0 959 801 AH    HW: 6R0 959 801 AH  Labels: 6R0-959-801.CLB
   Serial number: 13202579140604203140
   Coding: 010000
   Subsystem 3 - Part No SW: 31G 959 442     HW: 31G 959 442
   Serial number: 2421611332400361CX3J
   Coding: 250000
   Subsystem 4 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Serial number: 13202580140618015839
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13102581140804092028
   Coding: 020000
   Component: VW10AirbagU0F H10 0020
   Revision: --------    Serial number: 003GW00VGPPJ
   Coding: 003046
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 499921FEE874830C8F-801C
   Part No SW: 6RF 920 860 Q    HW: 6RF 920 860 Q
   Component: KOMBI         H02 0152
   Coding: 140A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04719
   VCID: 58BFF4BA23DEEA8400-800C
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H34 0424
   Revision: BF034001
   Coding: 002300
   VCID: 70EFAC1AA36E92C4E8-8024
   Component: IMMO          H02 0152
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADBBE728DB26814A6-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000010000
   Shop #: WSC 83300 833 00001
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 418939DED0444B4C57-8014
End-------------------------(Elapsed Time: 02:26)--------------------------
Excellent!
Thanks for posting the Autoscan one year later.
I suppose you live outside of our solar system.
I'm excited, it's my first extraterrestrial contact.
I will post my answer to your question immediately, I guess you will receive it within a year. :lol:
Now seriously, please tell me what you have tried so far to try to make work the paddle shifters with your automatic gearbox. Thanks.
I will wait for your reply... Image
bladekiller
Drives: 1.6 MPI
ciclo wrote: Sat May 19, 2018 6:28 am Excellent!
Yeah I know it’s a year late, haha. Just got time to get it done up.
So far I have only tried various codings but to no avail.
Ok, I'll have to review the Elsawin diagrams and other information ... wait please.
bladekiller
Drives: 1.6 MPI
ciclo wrote: Sat May 19, 2018 6:39 am Ok, I'll have to review the Elsawin diagrams and other information ... wait please.
Thanks.. my friend and I also went through Elsawin quite extensively. Hopefully we are able to get a breakthrough :idea:
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
Funny :)
http://www.mytiguan.com/index.php?/topi ... n-not-dsg/ (Hugs to Ruben :))
Please, take screenshots or images from these drop-down menus in Engine unit. Byte1
bladekiller
Drives: 1.6 MPI
ciclo wrote: Sun May 20, 2018 6:44 am http://www.mytiguan.com/index.php?/topi ... n-not-dsg/ (Hugs to Ruben :))
The variant we have here does not support engine long coding helper.
bladekiller
Drives: 1.6 MPI
bump..
Rex-17
Drives: polo mpi 1.6
Post by Rex-17 »
U need to use any vw steering paddle shift 2018 above
