Page 2 of 3
Re: Auto Light with CH-LH on Polo 6R 12/2009 with DSG and RLS
Posted: Wed Aug 22, 2018 9:28 pm
by ciclo
Boumbo02 wrote: Wed Aug 22, 2018 9:44 am Now the auto-light works but without CH-LH...
Maybe the problem is that you don't know how it works.
Coming Home. Semiautomatic.
- Ignition switch OFF
- Pull from High Beam stalk/lever once (flash).
- Open the driver's door. Lights turn on.
It will work equally if you already have the door open.
And NO... not is possible in automatic mode.
Leaving Home is automatic... when you open the car with remote the lights turn on.
Boumbo02 wrote: Wed Aug 22, 2018 9:44 am - The rear fog light does not work anymore (linked to the das board light failure indicator illuminated) : I don’t know why as I checked the bulb is in good condition.
- Check the splice.
- Check T73a/6 (power-output)
- Check T73b/43 (signal)
Boumbo02 wrote: Wed Aug 22, 2018 9:44 am - The indicator of the Tire Pressure remains illuminated at the dash board and the reset button (inside the glove box) does not work to cancel it.
- The indicator of the ESP remains illuminated at the dash board and the reset button does not work to cancel it.
1st... clear all DTCs with VCDS. (to clear intermittent faults)
Question:
When installing the steering angle sensor, did you take into account that it has to have the same turns on each side?
It's highly likely that you've broken the internal cable of your sensor if you didn't take it into account when you installed it. (when turning the steering wheel)
In the following image you can see the cable to which I refer...
... but your sensor doesn't have this verification window, so your cable is not visible.
Another possible cause is that you haven't pressed with enough force the locking mechanism of T41 connector.
Posted: Wed Aug 22, 2018 9:37 pm
by iichel
If the tape of the clock spring has been torn, I'd also expect an error for the driver side airbag igniter and the MFS not being detected.
Posted: Thu Sep 27, 2018 3:14 pm
by Boumbo02
Dear ciclo and iichel,
Thank you for your advises.
Concerning the steering wheel position sensor :
I whitnessed that it was not working correctly because the right cornering light was still working while the wheels were straight.
Then, by turning the steering wheel, I tested when the cornering lights went out and when the left cornering light switched on.
Thus I concluded that the steering wheel position sensor had one turn right offset when I reinstalled the steering wheel after BCM Max installation.
I then removed the steering wheel, turned the sensor one turn left and reinstalled the steering wheel.
After that the cornering lights worked well, and after DTCs clearing, there was no fault remaining due to the ESP and TPMS and these indicators have switched off on the instrument cluster.
After that I installed the additionnal wiring loom to restore the DRL function with the BCM Max.
When plugging the DRL loom terminals in the BCM plugs, I controlled the T73a/6 terminal for rear fog light power : no problem.
I then controlled the splice : I pulled on the wires but it remained crimped.
I then controlled the rear fog light bulb : in good condition.
I then controlled the fuse 18 : in good condition.
I then controlled the currents with help of a 12V lamp with long wires :
When the rear fog light is switched OFF at the light switch :
- The rear fog light indicator remains switched OFF at the instrument cluster.
- No current at the splice (neither at the black wire side, nor at the grey/black wire side).
- No current at the fuse 18 pins.
- No current at the rear fog light bulb socket.
When the rear fog light is switched ON at the light switch :
- The rear fog light indicator switches ON at the instrument cluster.
- +12V current arrives at the splice (at the black wire side AND at the grey/black wire side).
- +12V current arrives at the fuse 18 pin.
- No current at the rear fog light bulb socket (no current at the grey wire at the rear left tail-light plug).
- The indicator that warns for lamp fault switches ON at the instrument cluster.
When installing the BCM Max wires with auto lights, I only worked on the things you described on the document you issued for my Polo wiring configuration.
The rear fog lamp was working well before doing the wiring modifications for BCM Max installation .
Could you please help me clear this problem?
Thank you.
Posted: Thu Sep 27, 2018 5:36 pm
by ciclo
Please check the T3aa connector (if possible take pictures).
Please make a new autoscan and post here, it may be necessary to correct some codings/adaptations/installation list from some units.
Posted: Thu Sep 27, 2018 5:51 pm
by ciclo
Posted: Thu Sep 27, 2018 8:44 pm
by Boumbo02
Hello Ciclo,
Thank you for your prompt reply.
I would like to avoid parting the whole car into single parts to find this thing.
As far as I understand: items 10, 20, 13, 26 & 40 are located outside the car, after the grommet 16 and behind the rear bumper, I am right ?
Could you confirm that I need to remove the rear bumper to find this T3aa connector ?
Posted: Fri Sep 28, 2018 8:34 am
by ciclo
ciclo wrote: Thu Sep 27, 2018 5:36 pm Please make a new autoscan and post here, it may be necessary to correct some codings/adaptations/installation list from some units.
Posted: Fri Sep 28, 2018 8:59 am
by ciclo
You don't have to remove the rear bumper.
Seems that there are two trailer power socket versions, and it's high likely that your 6R will have the version without the T3aa connector.
by Boumbo02
Hi Ciclo,
As I am not car electrician engineer, I started to look for the T3aa switch by following the grey wire which supplies the rear fog light at the left tail light.
For that I have had to remove the interior trim of the trunk to be able to see and follow the wires wrapped and cliped on the car body inside the trunk.
This led me to the grommet that separates the inside of the car from the outside where the electrical looms goes out to supply the registration plate lamps and the trailer's power socket.
The T3aa switch is part of the trailer's power socket: its role is to shut off the car's rear fog light when plugging a trainer.
It operates by te help of a small hook inside the trailer's power socket (grey finger Inside the plug).
I did not manage to extract it from the trailer's power socket.
I operated the hook several times and the failure disappeared.
It may have been faulty before the BCM Max upgrade but I did not whitnessed it before.
Finally the autoscan is now as before BCM Max upgrade:
Thursday,27,September,2018,23:35:14:00001
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZAY127028   License Plate: AH-803-EH
Mileage: 197760km-122882mi   Repair Order: Rear Fog Lamp problem cleared
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56 69 0B
VIN: WVWZZZ6RZAY127028   Mileage: 197760km-122882miles
61-Battery Regul. -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 AH    HW: 03L 906 023 D
   Component: R4 1.6l TDI   H13 9980
   Revision: --H13---    Serial number:
   Coding: 00254014002400080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM16TDI02103L906023AH 003015
   ROD: EV_ECM16TDI02103L906023AH_003.rod
   VCID: 6CD6FC2C878BF62646-8038
1 Fault Found:
14355 - Exhaust Gas Temperature Sensor; B1 S3
          P242A 00 [044] - Malfunction
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 13
                    Mileage: 197328 km
                    Date: 2018.09.23
                    Time: 11:41:59
                    Engine speed: 1847.75 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 97 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 24 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 14.118 V
Readiness: 0 1 0 0 0
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 049     HW: 0AM 927 769 D
   Component: GSG DSG AG7     402 9030
   Revision: 00040024    Serial number: TFK00911060448
   Coding: 0000020
   Shop #: WSC 41554 001 1048576
   VCID: 6ED2F6247A97043668-513C
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 R    HW: 6R0 907 379 R
   Component: ESP8.2i front H04 0002
   Revision: --------
   Coding: 210228E3416F00B9842514E482D900421300
   Shop #: WSC 02069 000 00000
   VCID: 4D9051A810D11F2E31-8018
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 E    HW: 6R0 820 045 E
   Component: Climatic       24 0600
   Revision: 00 10 24
   VCID: 306E285C632352C63A-8064
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
            014 - Defective
                    Fault Status: 01101110
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 23414 km
                    Time Indication: 0
                    Date: 2010.10.12
                    Time: 08:34:21
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H78 0725
   Revision: B9078001    Serial number: 0671 083151292
   Coding: 3EB02BBF08A1000001380EB07CEB0ED05F80612F60842041200000030000
   Shop #: WSC 00049 770 00138
   VCID: 2F6C2B207E1D4D3E23-807A
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 191109 05  54  0402
   Coding: 06302D
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0902
   Serial number: KU0-KU011.11.0913717
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU010.11.0913768
   Coding: 08BC30
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0100378
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  005 0803
   Serial number: KU0-KU002.11.0912924
   Coding: 08BC32
   Subsystem 6 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  005 0803
   Serial number: KU0-KU027.10.0911220
   Coding: 08BC32
1 Fault Found:
01502 - Bulb for Rear Fog; Left (L46)
            010 - Open or Short to Plus - Intermittent
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 9
                    Reset counter: 53
                    Mileage: 197719 km
                    Time Indication: 0
                    Date: 2013.02.17
                    Time: 08:49:16
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag008 H09 0018
   Revision: --------    Serial number: 003DW008VNP6
   Coding: 003038
   VCID: 428A7294D58FD056DC-8016
   Serial number: 3572SRB40000A0E09A89
   Serial number: 3582SRB40000A3345AC6
   Serial number: 3516GRB40319LBCGS4FL
   Serial number: 3526GRB40319LBCH6K8A
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 861 D    HW: 6R0 920 861 D
   Component: KOMBI         H03 0205
   Coding: 140A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   VCID: 36621E4489477CF660-8062
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H78 0725
   Revision: B9078001
   Coding: 002200
   VCID: 70EEE85CA3A312C67A-8024
   Component: IMMO          H03 0205
   Serial number:
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
   VCID: 6ADAFA348D7FE81634-803E
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10130
   Shop #: WSC 00000
   VCID: 2E523624ED17443628-807A
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2I6866427
   Coding: 0500040002
   VCID: 6BD4FF308A85F11E4F-803E
1 Fault Found:
03138 - Input AUX IN
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 197720 km
                    Time Indication: 0
                    Date: 2013.02.17
                    Time: 08:50:18
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H07 0070
   Revision: 3A001001    Serial number: 00000123740429
   Coding: 410D000100000000
End-------------------------(Elapsed Time: 03:36)--------------------------
Address 17: DTCs cleared
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 44: DTCs cleared
Address 56: DTCs cleared
Address 69: DTCs cleared
Readiness: 0 0 0 0 1
   Coding: 0000020
   Revision: --------
   Revision: 00 10 24
1 Fault Found:
            014 - Defective
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 23414 km
                    Time Indication: 0
                    Date: 2010.10.12
                    Time: 08:34:21
   Coding: 06302D
   Coding: 08BC30
   Coding: 08BC30
   Coding: 020000
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003038
   Coding: 140A00
   Revision: B9078001
   Coding: 002200
   Serial number:
   Coding: 10130
   Shop #: WSC 00000
   Coding: 0500040002
End-------------------------(Elapsed Time: 03:54)--------------------------
   Coding: 0000020
   Revision: --------
   Revision: 00 10 24
1 Fault Found:
            014 - Defective
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 23414 km
                    Time Indication: 0
                    Date: 2010.10.12
                    Time: 08:34:21
   Coding: 06302D
   Coding: 08BC30
   Coding: 08BC30
   Coding: 020000
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003038
   Coding: 140A00
   Revision: B9078001
   Coding: 002200
   Serial number:
   Coding: 10130
   Shop #: WSC 00000
   Coding: 0500040002
1 Fault Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 197766 km
                    Time Indication: 0
                    Date: 2013.02.17
                    Time: 23:41:49
End-------------------------(Elapsed Time: 03:41)--------------------------
I consider the BCM Max upgrade and and the Autolight upgrade with CH-LH done !
Thank you for your support :wink:
I now have an exhaust gas temperature sensor problem to fix ...
Posted: Fri Sep 28, 2018 9:07 am
by ciclo
Impossible to visualize the images.
Upload it to another server for hosting images or use the forum's image hosting.
For example: https://imgur.com/upload
Posted: Fri Sep 28, 2018 9:12 am
by ciclo
In any case, the most important thing is the new autoscan ....
Posted: Fri Sep 28, 2018 10:39 am
by Boumbo02
ciclo wrote: Fri Sep 28, 2018 9:07 am Impossible to visualize the images.
I have corrected typing errors in the image's links and updated my post :wink:
Posted: Fri Sep 28, 2018 10:44 am
by iichel
Can confirm pictures work properly. Good to hear you fixed it, congratulations.
Posted: Fri Sep 28, 2018 11:16 am
by ciclo
Boumbo02 wrote: Fri Sep 28, 2018 10:39 am
Boumbo02 wrote: Fri Sep 28, 2018 8:59 am
   Coding: 0000020
   Revision: --------
   Revision: 00 10 24
1 Fault Found:
            014 - Defective
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 23414 km
                    Time Indication: 0
                    Date: 2010.10.12
                    Time: 08:34:21
   Coding: 06302D
   Coding: 08BC30
   Coding: 08BC30
   Coding: 020000
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003038
   Coding: 140A00
   Revision: B9078001
   Coding: 002200
   Serial number:
   Coding: 10130
   Shop #: WSC 00000
   Coding: 0500040002
1 Fault Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 197766 km
                    Time Indication: 0
                    Date: 2013.02.17
                    Time: 23:41:49
Perfect. Thanks for the images.
The problem was solved :arrow: viewtopic.php?f=56&t=70853&start=15#p542383 (this part it's not for you Boumbo02, it's in case someone has some kind of intellectual disability :lol:)
To clear address 61 from the installation list with VCDS you have to do the following:
-Re-register address 61 in the gateway installation list. (address 19)
-Codify address 61 with this coding--> 00000000 (address 61).
-Unmark again address 61 from gateway installation list. (address 19).
-Go to autoscan --> click gateway installation list - wait - and click in Clear all DTC's.
Address 61 must disappear from installation list.
Posted: Wed Oct 03, 2018 8:59 am
by Boumbo02
ciclo wrote: Fri Sep 28, 2018 11:16 am
Why is it necessary to clear address 61 from the CAN installation list?
I see that address 61 is listed when starting auto-scan but there is no report of address 61 in the scan.
My car does not have a module at the arrdess 61 (Battery regul) ?
