Retrofit golf mk7 steering wheel on polo mk5
firebulletz
Drives: Polo comfortline 1.6 tdi 90cv
Re: Retrofit golf mk7 steering wheel on polo mk5
Post by firebulletz »
ciclo wrote:wow! nice device.
Do you have the installation instructions for the CANBUS decoder?
I mean to the wires assignment...
Thank you![emoji16]
There is not a manual or instruction for it.
Inviato dal mio SM-G935F utilizzando Tapatalk
That's not good. Contact the seller and ask for it, it's absolutely necessary.
firebulletz
ciclo wrote:That's not good. Contact the seller and ask for it, it's absolutely necessary.
the seller told me that the canbus is only equipped with the connector that goes into the radio cables.
If indeed the seller is right (and the canbus os must be connected only with radio cables), how the steering wheel commands come to the radio? through which wiring?
Why this canbus (on photo) have 2 connectors, one to radio cable and one that should be connected elsewhere?Image
by the looks of it, the black connector has +15 (brown) +30 (yellow) GND (black) and illumination (orange)
I guess some other signals could be handbrake, remote, speed signal, reverse
firebulletz wrote: Wed Feb 07, 2018 1:09 pm how the steering wheel commands come to the radio? through which wiring?
LIN (buttons) <--> Gateway <---> CAN BUS (radio)
Black connector,,, supply, "comunication".
Brown connector... speakers
Maybe that set of wires is not right for your 6R.
NO OEM = ....
Another possible problem that is added to the existing ones with the MFSW. :lol:
firebulletz
NO OEM = ....
Another possible problem that is added to the existing ones with the MFSW. [emoji38]
This is my radio cable and canbusImageImageImageImageImage
With this set of wires everything seems correct.
firebulletz
ciclo wrote:With this set of wires everything seems correct.
Ok perfect. With this cables connection the steering wheel controls signal arrives at the radio?
Tomorrow my electrician will send me the autoscan with vcsd.
One other question: with the radio cable "brake" what can i do? What is it for? In the radio settings there is the option "brake signal" but i don't know what is.Image
firebulletz
What do you think? :D
I will change all inner led with white and the needles of tachometer color blue.Image
firebulletz wrote: Thu Feb 08, 2018 8:15 pm Ok perfect. With this cables connection the steering wheel controls signal arrives at the radio?
It should get to.
firebulletz wrote: Thu Feb 08, 2018 8:15 pm Tomorrow my electrician will send me the autoscan with vcsd.
The key of this...
firebulletz wrote: Thu Feb 08, 2018 8:15 pm One other question: with the radio cable "brake" what can i do? What is it for? In the radio settings there is the option "brake signal" but i don't know what is.
Read the device instructions. :lol:
...hmm... maybe it may be that the screen shows a car braking (in case of parking assistance).
If I continue supposing things ... maybe we end up crying with laughter.
It's logical to think that I do not have to know how all these devices NOT OEM work, there are millions of them for sale.
Why are you asking me these questions? :lol:
firebulletz wrote: Thu Feb 08, 2018 8:18 pm What do you think? :D
https://uploads.tapatalk-cdn.com/201802 ... 338ef0.jpg
It is nice. Does it have a brightness regulator?
firebulletz
It should get to.
The key of this...
Read the device instructions. [emoji38]
Why are you asking me these questions? [emoji38]
Ahahahah sorry. But i have asked you to know in general what it might be useful for, because i have not idea [emoji23]
however, it does not have a brightness regulator but i will connect it to the internal leds of the machine that have the controller next to the light switch. I just have to figure out how to intercept the signal from the window switch of each window
firebulletz
I can't see this youtube video. I can't see all youtube video in your post[emoji21][emoji21]
Check in user control panel the display preferences.
firebulletz
ciclo wrote:Check in user control panel the display preferences.
This is vcds autoscanImageImageImageImage
