Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
Re: Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
To your questions by email:
YOU ---> Yesterday I started installing BCM 7E0 and Coming Leaving Home and autolights. I encountered a problem with remove pin connector from the fuse box. sb34 and sb39. Other cables are already installed.
I have a question. Can I attach to the Insturment Cluster T41 / 28 and 29 wires froem PDC LOW/HIgh? And second question: Where is the easiest way to add wires from the PDC button (2 wires)? I mean the other 2 wires from the button bundle, which is supplied from carstystems.pl
Read the installation guide. It's very clear what you have to do with the wires that reach the fuses 34, 39 and 59.
(WL2 image)
Mon Mar 05, 2018 :arrow: https://uk-polos.net/viewtopic.php?t=71015#p531151
Please request technical support to carsystem.com for issues related to the PDC system... or search the info in the forum/...my topic. Now i'm on vacation. Thanks.
Hmm... to prevent you from doing something catastrophic:
... PDC CAN lines ... connect to original powertrain CAN lines (for example, in original IC CAN lines), never in adapted IC CAN lines (WL1 image of installation guide) for BCM adaptation.
favi
Drives: 6R
Post by favi »
I made a modification with the Ciclo's instructions. Below I place a auto-scan VCDS with coding: 2DB02BBF08E1240092380E007C6B0DD000C0610F608C2001200000030000
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 15 17 19 25 2E 37 44 56 61 77 0B
VIN: WVWZZZ6RZBY   Mileage: 115250km-71613miles
2E-Media Player 3 -- Status: Not registered 0011
37-Navigation -- Status: Not registered 0011
44-Steering Assist -- Status: Not registered 0001
77-Telephone -- Status: Not registered 0011
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 D    HW: 03F 906 070 D
   Component: SIMOS10.20H02 9694
   Revision: --------    Serial number:
   Coding: 001900D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070D 003014
   ROD: EV_ECM12TFS_003_VW25.rod
   VCID: 234234CE2A4EB859D4-8076
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3217500B7842814E484DA00401300
   Shop #: WSC 27514 001 1048576
   VCID: 071A405EB2B67479A8-8052
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
                    Fault Status: 01100101
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 115259 km
                    Time Indication: 0
                    Date: 2018.08.10
                    Time: 00:10:16
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3251
                    Hex Value: 0x1B98
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Component: LENKW.SENSOR  H06 0070
   Serial number: 15031304651874
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF425BAE16C35B19B-802A
1 Fault Found:
1140738 - Steering angle sensor
          B1168 54 [009] - Missing Calibration / Basic Setting
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Voltage terminal 15: 11.80 V
                    Voltage terminal 30: 12.05 V
                    Terminal 15 status: On
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326CC18A6DB421D12F-8066
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Revision: B9080001    Serial number: 0771 071161174
   Coding: 2DB02BBF08E1240093380E007EEB0FD000C0610F608C2001200000030000
   Shop #: WSC 02737 022 157175
   VCID: 68D863E29BE89B0141-803C
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 170117 04  42  0106
   Coding: 008F77
   Subsystem 2 - Part No: 1K8 951 171 A
   Subsystem 3 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
6 Faults Found:
00975 - Heated Rear Window (Z1)
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 44307 km
                    Time Indication: 0
                    Date: 2016.12.08
                    Time: 06:00:26
01334 - Door Control Module; Rear Right (J389)
            004 - No Signal/Communication
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 44307 km
                    Time Indication: 0
                    Date: 2016.12.08
                    Time: 06:00:26
01333 - Door Control Module; Rear Left (J388)
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 219
                    Time Indication: 0
01332 - Door Control Module; Passenger Side (J387)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 219
                    Time Indication: 0
01331 - Door Control Module; Driver Side (J386)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 115259 km
                    Time Indication: 0
                    Date: 2018.08.10
                    Time: 00:00:03
            000 -  -  - Intermittent
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 115259 km
                    Time Indication: 0
                    Date: 2018.08.10
                    Time: 00:00:03
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00J3B65
   Coding: 003232
   VCID: 4A9CB96AED24491177-801E
   Serial number: 3575HRB40570G68U9HCH
   Serial number: 3585HRB40550G68U7HIK
   Serial number: 3515RRB405T0510IA8VI
   Serial number: 3525RRB405T0510IMOL.
   Part No SW: 6R0 920 870 B    HW: 6R0 920 870 B
   Component: KOMBI         H05 0609
   Coding: 140E01
   VCID: 3460C7929FA02FE13D-8060
   Revision: B9080001
   Coding: 042205
2 Faults Found:
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
03406 - Control Module for Battery Monitoring
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
   Component: IMMO          H05 0609
   VCID: 6ADC19EA8DE4A91157-803E
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0546
   Revision: A1001003    Serial number: 7663381433
   Coding: 010100
   VCID: 2A5CD9EA4564691197-807E
1 Fault Found:
03138 - Input AUX IN
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 0 km
                    Time Indication: 0
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 H    HW: 1T0 035 680 P
   Component: RNS-MID       H61 3970
   Revision: AB001001    Serial number: VWZ6Z7H7102097
   Coding: 0C010440010000A10001
   Shop #: WSC 05314 123 12345
   VCID: 3362C48E92AE28D924-8066
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 225
                    Reset counter: 219
                    Mileage: 114112 km
                    Time Indication: 0
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6AC8FEEA860C3940-807A
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
1 Fault Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Reset counter: 219
                    Mileage: 114112 km
                    Time Indication: 0
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0946
   Revision: --------    Serial number: 35502105015259
   Coding: 020100010000000000000101
   Shop #: WSC 00015 115 12345
   ASAM Dataset: EV_UHVPremi 002708
   ROD: EV_UHVPremi_002.rod
   VCID: 244037D22F40BF61AD-8070
3 Faults Found:
9455635 - Telephone Microphone
          B1048 13 [009] - Open Circuit
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 114114 km
                    Date: 2018.07.15
                    Time: 11:28:29
9457939 - Telephone baseplate
          B1051 13 [009] - Open Circuit
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 114114 km
                    Date: 2018.07.15
                    Time: 11:28:29
9458193 - Control Module for Cellular Telephone
          B1052 14 [009] - Open or Short to Ground
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 114114 km
                    Date: 2018.07.15
                    Time: 11:28:29
and after enabling the RLS function . long codding: 2DB02BBF48E1240093380E007CEB0FD000C0610F608C2001200000030000
Scan: 01 03 04 08 09 10 15 17 19 25 2E 37 44 56 61 6C 77 0B
VIN: WVWZZZ6RZBY   Mileage: 115370km-71687miles
10-Park/Steer Assist -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Cannot be reached 1100
77-Telephone -- Status: Malfunction 0010
Readiness: 0000 0100
   Revision: --------
   Coding: 01
1 Fault Found:
          B1168 54 [008] - Missing Calibration / Basic Setting
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 115259 km
                    Date: 2018.08.11
                    Time: 00:05:09
                    Voltage terminal 15: 12.10 V
                    Voltage terminal 30: 12.20 V
   Revision: 0002S 02
   Coding: 2DB02BBF48E1240093380E007CEB0FD000C0610F608C2001200000030000
   Coding: 0A8F77
6 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 115259 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 00:05:14
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 115259 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 00:05:14
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 115259 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 00:05:13
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 115259 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 00:05:13
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 115259 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 00:05:10
03789 - Terminal 75 Limp Mode Active
            000 -  -
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 115259 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 00:05:10
Address 10: Park/Steer Assist
Cannot be reached
   Coding: 003232
   Coding: 140E01
   Revision: B9080001
   Coding: 042205
3 Faults Found:
02873 - Control Module for Back-Up Camera (J772)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 225
                    Mileage: 115377 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 17:10:02
03075 - Parallel Parking Assistance Control Module (J791)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 225
                    Mileage: 115377 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 17:10:02
                    Fault Priority: 2
                    Fault Frequency: 11
                    Reset counter: 225
                    Mileage: 115259 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 00:20:05
   Coding: 010100
1 Fault Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 0 km
                    Time Indication: 0
   Coding: 0E010440010000A10001
3 Faults Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 23
                    Reset counter: 225
                    Mileage: 115256 km
                    Time Indication: 0
00857 - CD Changer Unit (R41)
                    Fault Priority: 5
                    Fault Frequency: 23
                    Reset counter: 225
                    Mileage: 115256 km
                    Time Indication: 0
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 225
                    Mileage: 115377 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 17:10:02
   Coding: 11250
   Shop #: WSC 00788
3 Faults Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 23
                    Reset counter: 225
                    Mileage: 115256 km
                    Time Indication: 0
                    Fault Priority: 5
                    Fault Frequency: 23
                    Reset counter: 225
                    Mileage: 115256 km
                    Time Indication: 0
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 225
                    Mileage: 115377 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 17:10:02
   Coding: 030B1A73
2 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 115259 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 00:06:09
02252 - Generator
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 115259 km
                    Time Indication: 0
                    Date: 2018.08.11
                    Time: 00:06:09
Address 6C: Back-up Cam.
Cannot be reached
3 Faults Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 115259 km
                    Date: 2018.08.11
                    Time: 00:05:09
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 115259 km
                    Date: 2018.08.11
                    Time: 00:05:09
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 115259 km
                    Date: 2018.08.11
                    Time: 00:05:09
End-------------------------(Elapsed Time: 04:04)--------------------------
There is no communication with the window controller and the MFSW is not working. :(
You have not followed any kind of instruction.
https://uk-polos.net/viewtopic.php?f=56&t=71015#p533107
Therefore
Replacement :arrow: http://wiki.ross-tech.com/wiki/index.ph ... eplacement
This Replacement procedure applies to PQ25 (BCM25) BCM vehicles without a KESSY (05-Acc/Start Auth.) module.
Make sure all vehicle remotes are present.
Run and save a complete Auto-Scan and save it prior to module removal. https://uk-polos.net/viewtopic.php?f=56&t=71015#p531150
Code the 19-CAN Gateway module with the Long Coding from the original module found in the Auto-Scan. 002200
Configure the 19-CAN Gateway module using the [Installation List] function in VCDS per the original Auto-Scan.
Enable the addresses that correspond to your 6R and disable the addresses that do not correspond.
Your 6R (addresses)
Code the replacement 09-Cent. Elect. (BCM) module with the Long Coding from the original module found in the Auto-Scan.
Disable Factory Mode
Remote Control Matching http://wiki.ross-tech.com/wiki/index.ph ... Adaptation
Clear all fault codes and verify all comfort functions and lighting is working as per design.
RLS coding
0728DD
Please, do not do anything catastrophic. :|
favi
Drives: 6R
Post by favi »
I don't like catastrophic :)
OK i did it:
Coding gateway 002200
Coding BCM 2DB02BBF08E1240092380E007C6B0DD000C0610F608C2001200000030000
Remove old remote keys
add two new remote key
Factory mode was inactive
All fault codes was cleaned.
And..
Scan: 01 03 04 08 09 15 17 19 25 2E 37 44 56 0B
VIN: WVWZZZ6RZBY   Mileage: 115480km-71755miles
   ASAM Dataset: EV_ECM12TSF02103F906070D 003014
   ROD: N/A
No ASAM data for: "EV_ECM12TSF02103F906070D" (VW25)
Readiness: 0110 0101
   Revision: --------
   Coding: 01
   ASAM Dataset: EV_LWSLKOVW25X 005001
   ROD: N/A
No ASAM data for: "EV_LWSLKOVW25X" (VW25)
   Revision: 0002S 02
   Coding: 2DB02BBF08E1240092380E007C6B0DD000C0610F608C2001200000030000
   Coding: 0728DD
5 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 115483 km
                    Time Indication: 0
                    Date: 2018.08.13
                    Time: 11:22:33
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 115483 km
                    Time Indication: 0
                    Date: 2018.08.13
                    Time: 11:22:33
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 115483 km
                    Time Indication: 0
                    Date: 2018.08.13
                    Time: 11:22:33
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 115483 km
                    Time Indication: 0
                    Date: 2018.08.13
                    Time: 11:22:33
            000 -  -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 115483 km
                    Time Indication: 0
                    Date: 2018.08.13
                    Time: 11:22:28
   Coding: 003232
   ASAM Dataset: EV_AirbaV1W0BPAVW250 A01001
   ROD: N/A
   Subsystem 1 - Serial number: 3575HRB40570G68U9HCH
   Subsystem 2 - Serial number: 3585HRB40550G68U7HIK
   Subsystem 3 - Serial number: 3515RRB405T0510IA8VI
   Subsystem 4 - Serial number: 3525RRB405T0510IMOL.
No ASAM data for: "EV_AirbaV1W0BPAVW250" (VW25)
   Coding: 140E01
   ASAM Dataset: EV_Okmbi_UDS_VDD_RM09 A04716
   ROD: N/A
No ASAM data for: "EV_Okmbi_UDS_VDD_RM09" (VW36 *)
   Revision: B9080001
   Coding: 002200
   ASAM Dataset: EV_Immo_USD_VDD_RM09 A03709
   ROD: N/A
No ASAM data for: "EV_Immo_USD_VDD_RM09" (VW36 *)
   Coding: 010100
1 Fault Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 0 km
                    Time Indication: 0
1 Fault Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 229
                    Mileage: 115480 km
                    Time Indication: 0
   Coding: 11250
   Shop #: WSC 00788
1 Fault Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 229
                    Mileage: 115480 km
                    Time Indication: 0
Lights work, keys work, lock/unlock working, engine works
MFSW not work, folding mirrors not work, lifting up and down the window doesn't work
your BCM is complaining that it cannot reach the four door control modules (and the MFSW is also not seen).
Can you check whether the wires is installed correctly (not shortcircuited or detached)? The doors and the MFSW live on the same LIN wire (T73b/17).
I'd suggest to check the continuity and voltage on the wire. Maybe it's 12V (short to plus) or 0V (short to GND)
favi
Drives: 6R
Post by favi »
I'm going to car and start checking T73b / 17 and T28a in the door.
favi, now that it seems that you really follow the instructions, we go to the splice wires part. I'm sure you do not make proper wire splices.
The instructions are very clear:
https://drive.google.com/file/d/1NNjJFk ... Z5eB8/view
https://drive.google.com/file/d/0B2nv91 ... dlUUk/view
SN-02C Tool... makes perfect splices in insulated terminals. (but you bought a s**t tool https://ibb.co/gDCmnn -I have one :wink:-)
Clearer impossible. :wink:
When we finish with the 'problems' of the doors and the steering wheel we will check what happens to your front PDC system, by courtesy, since it does not correspond to me.
Question:
Why do you want to install CAN lines when installing the front PDC if you already have the rear PDC system with the CAN lines included?
if you had read the instructions we would all be happier ... including me who spent time doing them ...
Not for you favi
Of course, the bad guy of this and many other movies is me ...
(I'm up to the b*lls)
favi
Drives: 6R
Post by favi »
I will Check all connections for MFSW door etc. After removing the problem, I will think about PDC and the rest (headlight washer system etc).
favi
Drives: 6R
Post by favi »
Hello :)
I checked all connections and I do not know what I did wrong.
PDC - I have a damaged front pdc sensor cable - I am waiting for a new one.
MFSW and horn - not work. I Add 2 wires -> Auto dimming from T3/1 and CCS grom T41/28.
And... what is this +15? I add wires from org T41 and T3.
When I connected the cable to the T28 / 16 my mirrors stop working - folding the mirrors (in BCM you can not see the mirrors), the windows do not leave.
When I disconnect from the T28 / 16 MFSW cable everything returns to normal.
I added the headlight range module. I have been connected to BCM.
I replaced the headlight lamps - LED Polo 6C
How should I connect daytime running and position lights to the BCM module?
Now:
Low beam, High beam (and flashing), fog, cornering lights, turn signals - everything works.
CH / LH works, dimming mirror works, auto lights works.
Headlight washer system and fluid level control work.
RVC works.
VCDS Scan:
Friday,02,November,2018,12:40:11:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWZZZ6RZBY   Mileage: 122930km-76385miles
55-Headlight Range -- Status: Cannot be reached 1100
   ASAM Dataset: EV_ECM12TFS0210F3906070D 003014
   ROD: N/A
No ASAM data for: "EV_ECM12TFS0210F3906070D" (VW25)
Cannot be reached
   Coding: 01
   Revision: 0002S 02
   Coding: 2DB02BBF48E1240093380E007CEB1FD000C0610F608C2001200000030000
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8610
   Serial number: KU0KU010091300015333
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8610
   Serial number: KU0KU006091300015370
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Serial number: KU0KU015031100013211
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  007 1611
   Serial number: KU0KU014031100013620
   Coding: 08BC32
3 Faults Found:
            000 -  -
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 122502 km
                    Time Indication: 0
                    Date: 2018.10.29
                    Time: 15:12:23
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus - Intermittent
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 122502 km
                    Time Indication: 0
                    Date: 2018.10.29
                    Time: 15:12:23
00979 - Lamp for Low Beam; Right (M31)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 122502 km
                    Time Indication: 0
                    Date: 2018.10.29
                    Time: 15:12:23
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231501401002
   Coding: 308002
   Shop #: WSC 07456 790 50316
   ASAM Dataset: EV_VW75XPakrAssis8K 001003
   ROD: N/A
   VCID: 3B72ECAEB2FEE099FC-806E
No ASAM data for: "EV_VW75XPakrAssis8K" (VW25)
1 Fault Found:
1113107 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 122502 km
                    Date: 2018.10.29
                    Time: 15:12:00
Address 15: Airbags        Labels: 5K0-959-655.clb
   Coding: 003232
   ASAM Dataset: EV_AirbaVW10BPVAW250 Unknown
   ROD: N/A
No ASAM data for: "EV_AirbaVW10BPVAW250" (VW25)
   Coding: 140E01
1 Fault Found:
13639168 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 122502 km
                    Date: 2018.10.29
                    Time: 14:39:53
   Revision: B9080001
   Coding: 002200
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 122502 km
                    Time Indication: 0
                    Date: 2018.10.29
                    Time: 14:40:22
   ASAM Dataset: EV_Imm_oUDS_VDD_RM09 A03709
   ROD: N/A
No ASAM data for: "EV_Imm_oUDS_VDD_RM09" (VW36 *)
   Coding: 010100
1 Fault Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 0 km
                    Time Indication: 0
2 Faults Found:
                    Fault Priority: 5
                    Fault Frequency: 119
                    Reset counter: 189
                    Mileage: 122496 km
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 5
                    Reset counter: 189
                    Mileage: 122496 km
                    Time Indication: 0
   Coding: 11250
   Shop #: WSC 00788
Address 55: Headlight Range
Cannot be reached
2 Faults Found:
                    Fault Priority: 5
                    Reset counter: 189
                    Mileage: 122496 km
                    Time Indication: 0
            011 - Open Circuit
                    Fault Priority: 5
                    Reset counter: 189
                    Mileage: 122496 km
                    Time Indication: 0
2 Faults Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 122502 km
                    Date: 2018.10.29
                    Time: 14:40:28
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 176
                    Mileage: 122502 km
                    Date: 2018.10.29
                    Time: 14:40:28
End-------------------------(Elapsed Time: 04:12)--------------------------
+15 is the positive feed for the multifunction steering wheel unit, mirror, and the cruise control system. Do you really need to ask this?
More information that you should already have:
T73b/17 (doors/MFSW LIN)
T73b/36 (alarm horn LIN)
T73b/24 (RLS/Humidity sensor/alarm interior sensors LIN)
favi
Drives: 6R
Post by favi »
Hello all :) I return after a long absence. I had a car accident at work. I managed to solve the problem with MFSW - everything works.
I installed Led headlight. However, according to the schema, DRL and Parking light are not working anymore.
LED stekker links
1 - AFS
2 - AFS
3 - AFS
4 - AFS
5 - Massa - Halogeen pin 5
6 - Dimlicht - Halogeen pin 6
7 - Massa - Halogeen pin 5
8 - Plus die van de hoogteregeling kwam - Stap 5!
9 - Knipperlicht - Halogeen pin 9
10 - LED module - T73b / 5
11 - Groot licht - Halogeen pin 8
12 - LED module - T73b / 3 - Deze zit evt al bij de DRL in de bumper!
13 - leeg
14 - LED module - T73b / 28
LED stekker rechts
1 - AFS
2 - AFS
3 - AFS
4 - AFS
10 - LED module - T73b / 6
12 - LED module - T73a / 5 - Deze zit evt al bij de DRL in de bumper!
13 - leeg
14 - LED module - T73b / 56
The BCM module that I have is BCM PQ25 Max4 H80 0733 7E0937090
7E0 937 090 Z4Y
Does anyone have any idea for connecting the correct one?
What is your coding of the BCM?
