Head unit - CarPlay/mirrorlink
Dink
- Drives: 2015 GTI
Re: Head unit - CarPlay/mirrorlink
Think you press menu then scroll over to settings then scroll down to system information.
It says 3QOO35820
Dink
- Drives: 2015 GTI
That's the unit that can't be upgraded.
The only route is to change the unit in the glove box. Then get it unlocked/programmed
Oh ok. Thank you! Do you know anything about mirrorlink? How I get the code to activate it?
Thank you! Reckon this’ll be easy to fit? Then I’d just have to get the upgrade? ..
Dink should be able to guide you on what’s needed
Dink
- Drives: 2015 GTI
It's easy to fit. Just get some vw removal keys and swap it over.
But it's best to look for someone local who has access to the vw main dealer software before doing anything.
The unit will work but will get locked as soon as it gets power. So you would need to get component protection removed this then disables bluetooth. So once CP is removed you will then need to get that re-enabled and then upgrade to app connect (there is going to be at least a charge for app connect)
I wouldn't bother with mirror link it's not worth it.
Seems either way I’m looking at around £300.... think I’ll jyst buy a Garmin and maybe pay to have it wired in... can’t stand trailing wires
Dink
- Drives: 2015 GTI
Yeah the unit that is in the glove box is cheap it's the Labour and code for app connect is the expensive part.
The app connect I'd say is worth it as it does integrate with your phone for more than just navigation.
I would agree, carplay is well worth it.
Thank you so much. I can connect my phone already so can play my music etc through the car system, I just needed satnav
It gives you all the apple music integration, maps, messages and full phone support - well worth the purchase
Dink
- Drives: 2015 GTI
one thing i will say is if you install a head unit into your car that is able to do car play/android auto
you get full use of it while component protection is active so you can see all functionality of it but there is no sound
I have a 2014 polo 6c and found this page. Really need carplay installed in my car
Ive gathered i need to buy 3q0035842b.
Whats next, how do i find someone who has access to wv main dealer software and what exactly am i asking them to do?
Thanks in advanced
Thanks in advanced
Dink wrote: Tue Apr 03, 2018 11:10 am It's easy to fit. Just get some vw removal keys and swap it over.
