FBZ Polo's
Re: FBZ Polo's
In the new value ALWAYS write 0 for all remote controls.
First remote control, write 0 and do the process.
Second remote control, write 0 and do the process.
As simple as that. http://wiki.ross-tech.com/wiki/index.ph ... l_Matching
Good luck!
Good luck!
- Drives: Polo comfortline 1.6 tdi 90cv
Re: FBZ Polo's
Thank you ciclo!ciclo wrote:In the new value ALWAYS write 0 for all remote controls.
Good luck! [emoji38]
The correct sequence is:
Enter "0" in new value -> click test -> click save -> press unlock button on key
For the second key repeat this procedure
Inviato dal mio SM-G935F utilizzando Tapatalk
Re: FBZ Polo's
R Steering wheel looks perfect. (challenge achieved)
Autoscan,... when possible for you.
Re: FBZ Polo's
I will do itciclo wrote:R Steering wheel looks perfect. (challenge achieved)
After changing the bcm I have a problem. The second click of the remote control buttons does not work to lower/raise the windows and the second click of the window switches does not work (only works on the driver's side).
There is an option on vcds to enable/disable it?
Re: FBZ Polo's
did you re-learn comfort function? close windows and hold up each button for 3 seconds?
Re: FBZ Polo's
Resolved thank youiichel wrote:did you re-learn comfort function? close windows and hold up each button for 3 seconds?
Next step is fix the errors on autoscan. Tomorrow i will do autoscan
Re: FBZ Polo's
This is my autoscan:
Monday,14,May,2018,19:39:33:00001
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY080849 License Plate:
Mileage: 214780km-133458mi Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 04 08 09 15 17 19 25 37 44
VIN: WVWZZZ6RZCY080849 Mileage: 214780km-133458miles
37-Navigation -- Status: Not registered 0011
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MA HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 8849
Revision: --H33--- Serial number:
Coding: 00114016002400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02103L906023MA 003004
ROD: EV_ECM16TDI02103L906023LL.rod
VCID: 71E8ED58A0A91BCE75-8024
1 Fault Found:
10119 - High Pressure Fuel Rail
P00C6 00 [096] - Minimum Pressure Not Reached
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 67595 km
Date: 2018.05.06
Time: 00:01:11
Engine speed: 312.75 /min
Normed load value: 10.2 %
Vehicle speed: 0 km/h
Coolant temperature: 22 C
Intake air temperature: 22 C
Ambient air pressure: 990 mbar
Voltage terminal 30: 10.278 V
Unlearning counter according OBD: 26
Fuel high pressure: actual value-FUP_FIL: 3.497 MPa
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
Fuel level-FTL_CAN: 20 l
Time since engine start: 0 s
Fuel Metering Valve-VCV: 33.113 %
Fuel Pressure Regulator Valve-PCV: 46.288 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 28515.625 kPa
Readiness: 1100 0000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3417500B2842D14E682DA00421100
VCID: 071CA380B22D357ECB-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326A22546D2F60D64C-8066
Part No SW: 6R0 937 087 AD HW: 6R0 937 087 AD
Component: BCM PQ25 H+4 H42 0452
Revision: BF042001 Serial number: 5400 261170646
Coding: 3CB02BBF08A10000003808006D0B0CD00080412F60860060200000000000
Shop #: WSC 12345 123 12345
VCID: 7F0C3B60EEFD7DBEF3-802A
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU025081100010210
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU001091100015461
Coding: 08BC30
Subsystem 3 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H04 0103
Serial number: 39170001271300057197
Coding: A4FFFF
Subsystem 4 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU017081100014087
Coding: 08BC32
Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU030081100014426
Coding: 08BC32
2 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 42
Time Indication: 0
00446 - Function Limitation due to Under-Voltage
Fault Priority: 6
Fault Frequency: 3
Reset counter: 42
Time Indication: 0
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00UZUX8
Coding: 003232
VCID: 4A9A5AB4EDBF081614-801E
Serial number: 3575HRB40690OCUIB06N
Serial number: 3585HRB40690OCUIDPHJ
Serial number: 3515RRB405B0M98E4981
Serial number: 3525RRB40650MFP6O92Q
1 Fault Found:
12854016 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [008] - -
Fault Priority: 6
Fault Frequency: 23
Reset counter: 42
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
Component: KOMBI H04 0206
Serial number: 00000008663469
Coding: 540A00
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
VCID: 3A7A0A74BD5F989684-806E
1 Fault Found:
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Fault Priority: 6
Fault Frequency: 2
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6R0 909 901 HW: 6R0 937 087 AD
Component: GW-K-CAN TP20 H42 0452
Revision: BF042001
Coding: 002200
VCID: 74E6E44CD7BB2EE69E-8020
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 109
Reset counter: 255
Mileage: 214099 km
Time Indication: 0
Date: 2012.09.22
Time: 00:09:44
Address 25: Immobilizer (J285) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H04 0014
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
ROD: EV_ImmobUDSJCIPQ25.rod
Address 37: Navigation
Cannot be reached
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11220
Shop #: WSC 00788
VCID: 2F6C2B20EA1D4D3E23-807A
End-------------------------(Elapsed Time: 02:57)--------------------------
Now i am worried D:
www.Ross-Tech.com
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Mileage: 67595 km
Date: 2018.05.06
Time: 00:01:11
Revision: --------
Revision: 0002S 02
Coding: 18BC30
Coding: 08BC30
Coding: A4FFFF
Coding: 08BC32
Coding: 08BC32
2 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 42
Time Indication: 0
Fault Priority: 6
Fault Frequency: 3
Reset counter: 42
Time Indication: 0
Coding: 003232
1 Fault Found:
U0423 00 [008] - -
Fault Priority: 6
Fault Frequency: 23
Reset counter: 42
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 540A00
1 Fault Found:
U1400 00 [008] - -
Fault Priority: 6
Fault Frequency: 2
Revision: BF042001
Coding: 002200
1 Fault Found:
000 - -
Fault Priority: 2
Reset counter: 255
Mileage: 214099 km
Time Indication: 0
Date: 2012.09.22
Time: 00:09:44
Serial number:
Cannot be reached
Coding: 11220
Shop #: WSC 00788
Now i am worried D:
Re: FBZ Polo's
What is the state of the battery?
Re: FBZ Polo's
With headunit you mean bcm?
Re: FBZ Polo's
Radio-navigator-etc...
Re: FBZ Polo's
For radio i have these malfunction on autoscan (Voltage, fuel pressure)?ciclo wrote:Radio-navigator-etc...
Now that i Think about it, i have a smal problem. When I open the door when the car is on, the lights do not turn on and the doors do not unlock. they do it after a few seconds (4 sec, 20sec, 12sec).
This happens when the car is on or off, only with my door.
It's happened since I installed the inverter for the neon strip. It immediately burned and I started to have this problem. Obviously I removed it right away
Re: FBZ Polo's
I am back![emoji16][emoji16]
I have buyed a chinese autolights switch with ch/lh function. I have used more than one types of manual but ch/lh not work. I have buyed the switch with external module with sensor. I don't know what is the problem.
Re: FBZ Polo's
I think you forgot to 他媽的用中文說
(no honestly, I don't know how to fix it)
Re: FBZ Polo's
Lool [emoji23]iichel wrote:I think you forgot to 他媽的用中文說
