Page 2 of 2
Re: Sub power cable through firewall
Posted: Sat May 05, 2018 1:00 pm
by alexperkins
Posted: Sat May 05, 2018 1:01 pm
by alexperkins
That’s the only photo I could find of mine. You should be able to work out where i routed it via though
Posted: Sat May 05, 2018 1:45 pm
by TheRealRyno
Yeah I tried that one aswell I've just been struggling to remove the grommet. It's a lot harder than the first one. What's the best method?
Posted: Sat May 05, 2018 1:49 pm
by alexperkins
Squeeze and pull though I have a feeling a pierced a hole in it and siliconed it up
Posted: Sat May 05, 2018 1:51 pm
by TheRealRyno
I've removed it but the grommet looks designed to just hold one wire. So how do I protect the second wire from rubbing against the metalwork?
Posted: Sat May 05, 2018 1:53 pm
by alexperkins
Post some more photos if you can
Posted: Sat May 05, 2018 1:55 pm
by TheRealRyno
Posted: Sat May 05, 2018 1:56 pm
by TheRealRyno
What if I was to slit it open one side and wrap it round both wires then just push it back into the hole. Would something like that work?
Posted: Sat May 05, 2018 1:57 pm
by alexperkins
That’ll work. Do that
Posted: Sat May 05, 2018 1:58 pm
by TheRealRyno
Okay I'll give it a go thanks for your help. I'll post later to let you know how it goes.
Posted: Sat May 05, 2018 6:42 pm
by TheRealRyno
Took a while but I got it all sorted and wired up in the end. Cheers for your help Alex. Much appreciated.
