Does a Water pump replacement also need timing belt done?
Re: Does a Water pump replacement also need timing belt done?
I believe that is correct, well I know that it is the way things are for the 1.2TSI 16V engines.
Just want to lend my support to the above, VW themselves confirm the petrol engine found in the Polo 6C 1.2 Tsi (CJCZ) does not require water pump to be changed when you replace timing belt...so that’s something, wonder where the Dealer will make up the lost revenue now
