Which lowering springs. Eibach or H&R
john__m
Drives: polo gti 6c
Re: Which lowering springs. Eibach or H&R
Post by john__m »
Think im going to go with eibach's due to the bad comments on the ride quality with h&r's
Andy1273
Drives: 1.2 tsi polo
Post by Andy1273 »
I've been looking into these. I've found 2 sets but unsure which to get, both Eibach. The only difference I can see is the axle weight difference so which do I get?
Set 1 front axle load 860 rear axle load 840
Set 2 front axle load 960 rear axle load 840?
Why the difference?
Andy1273 wrote: Thu Nov 22, 2018 8:29 pm I've been looking into these. I've found 2 sets but unsure which to get, both Eibach. The only difference I can see is the axle weight difference so which do I get?
Why the difference?
Different Polo models have different axle load limits. Axle load limits for the 6c Polo are on pages 50-53 of the brochure at the link below;
https://www.volkswagen.co.uk/assets/com ... ochure.pdf
marin6r
Drives: Polo 6R 2010
Post by marin6r »
Are your Eibach springs also 35/55?
Dink
Drives: 2015 GTI
Post by Dink »
marin6r wrote: Tue Nov 27, 2018 5:58 pm Are your Eibach springs also 35/55?
No they are about 25-30 mm front and rear
CKarhu
Drives: Polo 6C 2015
Post by CKarhu »
Hi!
Thought I'd have your opinion on something I messed up with... I have a Polo 6c 2015 1.2 TSI 16V and fitted a Eibach Pro-Kit, but I accidentally ordered the GTI version. Rear springs are, if not mistaken, the same. But front ones are built for up to 960 kg instead of 870 kg. How would this in theory affect my car? It's a bit stiffer, not bad considering I also run on 215/40/17 wheels. High speed drive is also stable, nothing to complain about there.
Thanks in advance!
kwangming
Drives: Vw polo 1.2 tsi
Post by kwangming »
Anyone not using the H&R 35/55 28974-2 for vw polo 6r and try to sell them?
Because im interested to fit them to my polo
3lf
Drives: R line 1.0 TSI
Post by 3lf »
Dink wrote: Fri Oct 19, 2018 8:16 pm This is with the eibach springs fitted. It's a subtle drop and is about right imho.
Did you have to change the shock absorbers or keep your stock ones?
I will be lowering front: 25 mm Rear: 30 mm.
Dink
Drives: 2015 GTI
Post by Dink »
3lf wrote: Mon Sep 09, 2019 1:39 pm
Stock shock absorbers as I've got the sport pack on my car
JaegerStriker
Drives: 6C GTI
Post by JaegerStriker »
ive used both. H&r are very stiff but handle well and look loads better but eibach are best all round, subtle drop and increase handling over standard.
Aquavalver
Drives: 2013 Polo Blue GT
Post by Aquavalver »
Alexnesta wrote: Mon Oct 22, 2018 7:32 pm I used Eibach and H&R, with H&R the car was very short and nice but it bounced all the time my car is a 6R Blue GT. After a week of use, Mount Eibach again as the car worked really badly. I bought H&R 35 / 55mm. I sincerely recommend eibach
Eibach:
H&R
Sorry for my english
Is there much difference in the height of the car with each spring set? It's hard to tell from the photos as the first photo with H&R springs the photo is taken lower down compared to the photo with Eibach springs where the photo is taken higher up! In the two photos the car looks lower with the Eibach springs! Do Eibach only do the one height drop? I have a Blue GT which is 15mm lower than standard, so it would only be lowered 15mm more. Is it worth it for that?
