How to replace your alarm horn
Franciswat
Drives: 6R 1.6 Bifuel
Re: WIP: how to replace your alarm siren box back up battery
Post by Franciswat »
Well I am not an electrician and my knowledge about this stuffs is limited but I supposed since batteries are connected in series they should charge/discharge together.
I checked them both when they arrived but maybe a battery was defective or maybe I damaged It inadvertently when I soldered contacts the pbc!
Anyway new battery is coming and I'll give siren an other chance to work!
Stay tuned! :wink:
Franciswat
Hi guys, last update for this story.
Unfortunatelly I have to comunicate that even If both batteries had been replaced with new one the error on VCDS did not disappear. :(
For this reason I will replace the whole horn unit soon. Anyway the horn continues to works correctly as far as I tested it.
Too bad it didn't work out as you planned, but thanks for trying anyway!
It was worth trying though - just one thing maybe a stupid thought, will these new batteries not need time to charge up before the fault can be erased?
Sorry if you have given the batteries time to recharge - did you check that there is a supply getting through to this box to keep these back up batteries charged up, or maybe the built in charger has been trashed by the previous batteries failing, or a protective fuse?
Franciswat
Hello guys, sorry for late reply but I forgot to subscribe to the topic.
Thanks iichel I just thought replacing the battery could be a cheaper solution than replacing the whole unit. :roll:
Never give up until you have tried all the ways you can!
Yes I thought that but after a long drive and some weeks batteries should be fully charged but error remains. :|
Since batteries are good I may only suppose there is something wrong in the PCB but I should ask an electronic technician because my knowledge about electric components is very limited. :roll:
Good Good, you will get there in the end, keep up the good work! (Good Luck!!)
Franciswat
I have finally replaced the faulty alarm horn (1K0951605C) with a more recent unit (1K0951605F).
:arrow: How to remove the alarm horn
:arrow: viewtopic.php?f=56&t=72126&p=543845#p543845
New autoscan (no more errors) :wink:
Friday,30,August,2019,16:56:38:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY540000   License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 55 56 0B
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 210224E3217100B5842524E484D700401300
   Shop #: WSC 00788 648 00255
   VCID: 00085B4297984341E9-8054
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 397EF6A6B0C2D289EE-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Revision: B9080001    Serial number: 0771 060161479
   Coding: 3CB02BBF08E1240092380E916C6B0DD1DAC0672F608D30D0200000030000
   Shop #: WSC 02737 534 00190
   VCID: 68D863E29BE89B0141-803C
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU004011200011991
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU005011200017885
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29170002240760027504
   Coding: A40000
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU010011200012406
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU009011200013136
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0106
   Revision: --------    Serial number: 20231629400567
   Coding: 108001
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_VW75XPakrAssis8K 001003
   ROD: N/A
   VCID: 3B72ECAEB2FEE099FC-806E
No ASAM data for: "EV_VW75XPakrAssis8K" (VW25)
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX011W0JJ
   Coding: 003232
   ASAM Dataset: EV_AirbaV1W0BPAVW250 A01001
   ROD: N/A
   VCID: 4A9CB96AED24491177-801E
   Subsystem 1 - Serial number: 3575HRB4059124B2F99H
   Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
   Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
   Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaV1W0BPAVW250" (VW25)
   Part No SW: 6R0 920 871 A    HW: 6R0 920 871 A
   Component: KOMBI         H03 0505
   Coding: 140E01
   ASAM Dataset: EV_KombiU_DS_VDD_RM09 A04113
   ROD: N/A
   VCID: 3460C7929FA02FE13D-8060
No ASAM data for: "EV_KombiU_DS_VDD_RM09" (VW36 *)
   Revision: B9080001
   Coding: 002200
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADC19EA8DE4A91157-803E
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6AC8FEEA860C3940-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0110000001000000
   ASAM Dataset: EV_HealdRegulVWLWRPt 001004
   ROD: N/A
   VCID: 77FA309ECE5604F9D8-8022
No ASAM data for: "EV_HealdRegulVWLWRPt" (VW25)
Address 56: Radio (J503)       Labels: None
   Component: Radio         541 5314
   Revision: --------    Serial number: VWZZZ4K6200530
   Coding: 16000400040005
   Shop #: WSC 127395 840 08317
   VCID: 46848D5AF13CAD7193-8012
End-------------------------(Elapsed Time: 03:18)--------------------------
benzinkopf
Drives: 1.2TSI 105HP DSG7
Re: How to replace your alarm horn
Post by benzinkopf »
too bad. i just bought a used unit thinking i might be able to change the battery too[emoji23]
Franciswat
Changing the battery does not ensure to solve the problem.
Some people seem to get lucky, well maybe 1 person in 100!
Franciswat
Give it a try! :mrgreen: Maybe you're luky!
Mvplayer84
Drives: Polo 6r 1.4l
Post by Mvplayer84 »
Hi all. Sorry for reviving an old thread. Does anyone know what voltage comes to the siren signal wire to activate the alarm? I am getting 0.5v on the signal wire when alarm is in idle state (not triggered) and 0.8v when I trigger the alarm. How can I test the siren when it is removed from the car.
Mvplayer84
Franciswat
Have no idea about the voltages or how to test the syren outside the car.
What kind of issue do you have? Anyway I think will be easier to just replace it.
When I tried to fix mine by replacing the batteries I've spent money for nothing.
Do you lock your car via cobra remote or via central locking? It seems that both options activate the alarm?
