Page 2 of 3
Re: WIP: how to replace your alarm siren box back up battery
Posted: Wed Nov 28, 2018 10:10 pm
by Franciswat
Well I am not an electrician and my knowledge about this stuffs is limited but I supposed since batteries are connected in series they should charge/discharge together.
I checked them both when they arrived but maybe a battery was defective or maybe I damaged It inadvertently when I soldered contacts the pbc!
Anyway new battery is coming and I'll give siren an other chance to work!
Stay tuned! :wink:
Posted: Wed Apr 10, 2019 11:22 pm
by Franciswat
Hi guys, last update for this story.
Unfortunatelly I have to comunicate that even If both batteries had been replaced with new one the error on VCDS did not disappear. :(
For this reason I will replace the whole horn unit soon. Anyway the horn continues to works correctly as far as I tested it.
Posted: Thu Apr 11, 2019 6:13 am
by iichel
Too bad it didn't work out as you planned, but thanks for trying anyway!
Posted: Thu Apr 11, 2019 9:26 am
by RUM4MO
It was worth trying though - just one thing maybe a stupid thought, will these new batteries not need time to charge up before the fault can be erased?
Sorry if you have given the batteries time to recharge - did you check that there is a supply getting through to this box to keep these back up batteries charged up, or maybe the built in charger has been trashed by the previous batteries failing, or a protective fuse?
Posted: Fri May 10, 2019 12:18 am
by Franciswat
Hello guys, sorry for late reply but I forgot to subscribe to the topic.
Thanks iichel I just thought replacing the battery could be a cheaper solution than replacing the whole unit. :roll:
Never give up until you have tried all the ways you can!
Yes I thought that but after a long drive and some weeks batteries should be fully charged but error remains. :|
Since batteries are good I may only suppose there is something wrong in the PCB but I should ask an electronic technician because my knowledge about electric components is very limited. :roll:
Posted: Fri May 10, 2019 8:50 am
by RUM4MO
Good Good, you will get there in the end, keep up the good work! (Good Luck!!)
Posted: Fri Aug 30, 2019 4:28 pm
by Franciswat
I have finally replaced the faulty alarm horn (1K0951605C) with a more recent unit (1K0951605F).
:arrow: How to remove the alarm horn
:arrow: viewtopic.php?f=56&t=72126&p=543845#p543845
New autoscan (no more errors) :wink:
Friday,30,August,2019,16:56:38:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY540000   License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 55 56 0B
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 210224E3217100B5842524E484D700401300
   Shop #: WSC 00788 648 00255
   VCID: 00085B4297984341E9-8054
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 397EF6A6B0C2D289EE-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Revision: B9080001    Serial number: 0771 060161479
   Coding: 3CB02BBF08E1240092380E916C6B0DD1DAC0672F608D30D0200000030000
   Shop #: WSC 02737 534 00190
   VCID: 68D863E29BE89B0141-803C
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU004011200011991
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU005011200017885
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29170002240760027504
   Coding: A40000
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU010011200012406
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU009011200013136
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0106
   Revision: --------    Serial number: 20231629400567
   Coding: 108001
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_VW75XPakrAssis8K 001003
   ROD: N/A
   VCID: 3B72ECAEB2FEE099FC-806E
No ASAM data for: "EV_VW75XPakrAssis8K" (VW25)
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX011W0JJ
   Coding: 003232
   ASAM Dataset: EV_AirbaV1W0BPAVW250 A01001
   ROD: N/A
   VCID: 4A9CB96AED24491177-801E
   Subsystem 1 - Serial number: 3575HRB4059124B2F99H
   Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
   Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
   Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaV1W0BPAVW250" (VW25)
   Part No SW: 6R0 920 871 A    HW: 6R0 920 871 A
   Component: KOMBI         H03 0505
   Coding: 140E01
   ASAM Dataset: EV_KombiU_DS_VDD_RM09 A04113
   ROD: N/A
   VCID: 3460C7929FA02FE13D-8060
No ASAM data for: "EV_KombiU_DS_VDD_RM09" (VW36 *)
   Revision: B9080001
   Coding: 002200
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADC19EA8DE4A91157-803E
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6AC8FEEA860C3940-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0110000001000000
   ASAM Dataset: EV_HealdRegulVWLWRPt 001004
   ROD: N/A
   VCID: 77FA309ECE5604F9D8-8022
No ASAM data for: "EV_HealdRegulVWLWRPt" (VW25)
Address 56: Radio (J503)       Labels: None
   Component: Radio         541 5314
   Revision: --------    Serial number: VWZZZ4K6200530
   Coding: 16000400040005
   Shop #: WSC 127395 840 08317
   VCID: 46848D5AF13CAD7193-8012
End-------------------------(Elapsed Time: 03:18)--------------------------
Re: How to replace your alarm horn
Posted: Sat Aug 31, 2019 4:33 am
by benzinkopf
too bad. i just bought a used unit thinking i might be able to change the battery too[emoji23]
Posted: Sat Aug 31, 2019 8:43 am
by Franciswat
Changing the battery does not ensure to solve the problem.
Posted: Sat Aug 31, 2019 5:32 pm
by RUM4MO
Some people seem to get lucky, well maybe 1 person in 100!
Posted: Sat Aug 31, 2019 8:24 pm
by Franciswat
Give it a try! :mrgreen: Maybe you're luky!
Posted: Sat Jan 23, 2021 2:53 pm
by Mvplayer84
Hi all. Sorry for reviving an old thread. Does anyone know what voltage comes to the siren signal wire to activate the alarm? I am getting 0.5v on the signal wire when alarm is in idle state (not triggered) and 0.8v when I trigger the alarm. How can I test the siren when it is removed from the car.
by Mvplayer84
Posted: Sat Jan 23, 2021 4:07 pm
by Franciswat
Have no idea about the voltages or how to test the syren outside the car.
What kind of issue do you have? Anyway I think will be easier to just replace it.
When I tried to fix mine by replacing the batteries I've spent money for nothing.
Posted: Sat Jan 23, 2021 4:13 pm
by amer6R
Do you lock your car via cobra remote or via central locking? It seems that both options activate the alarm?
