Front nearside indicator bulb not working
Re: Front nearside indicator bulb not working
Still no idea as to the exact mechanism of failure though, so anyone out there, try to remember the "wiring through the adaptor" tip.
littlepolo
Yes, a bit of a fiddle but very doable.
I was hoping it wouldn't turn into two winters of discontent
which would have been enough to start to consider life beyond a Polo.
littlepolo
That is true. It's puzzling because the bulb holder is effectively a bayonet mount and holds quite firm.RUM4MO wrote: Mon Dec 17, 2018 3:18 pm Still no idea as to the exact mechanism of failure though, so anyone out there, try to remember the "wiring through the adaptor" tip.
If anyone experiences this problem it is probably more expedient to proceed with the fix rather than spend time on diagnostics.
