ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
I bought a new driver's door module from the VW dealer to be able to install the folding mirrors because the original (5Q4 959 393 F) does not have the necessary pins, but they sell it without parameterization 🥱, so it works erratically 🤪 (central locking, windows, etc).
The diagnosis informs us that the data is invalid.
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
Component: TSG FS 006 0246
Serial number: 0000343351044
Coding: 00110320D000048000001000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCID: 48C9A55C32341027165-801C
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000009798407
Coding: 010000
1 Fault Found:
196692 - invalid data record
B2005 00 [009] - -
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Mileage: 2746 km
Date: 2018.11.19
Time: 15:05:02
I went to the VW dealer to have it parameterized, but it seems that I was speaking to them in an alien language or something similar ... they tried to parameterize it but the VW server would not support installing the module due to original configuration of my wife's golf. (self-destructive rule)
They kept the module and gave me my money back.🤭
VCP server have the parameterization for index "E". I don't know if the module with index "F" can be parameterized with that data, so I bought a module with index F second hand.
I actually bought two second hand driver's door modules ✌ because one of them had been flashed, ... it was very cheap.😅
Both worked perfectly.👌
Golf 7.5 Folding mirrors.
Please read the previous post in case you need to change the door modules.
Ali :arrow: 5GG857507A , 5GG857508A.
Installation
I did the exact same thing shown in this magnificent video.
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/R4N3i5xRG ... autoplay=1
Perhaps the best video ever on installing and coding folding mirrors.
My coding:
G7.5 Folding mirrors.
Address 09:
 SECURITY ACCESS, 31347
Adaptation
 ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,active ,5
 ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by look command via remote control key ,5
 ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,active ,5
 ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5
 ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
 ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
 ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung,active ,5
 ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5
 ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
 ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
Addresses 42, 52:
Coding:
 Byte1 Bit0 (enable)
 Byte4 Bit4, Bit6 (enable)
 Byte1 Bit5  Door entry light inactive while Mirros folded (disable)
Autoscan
Wednesday,28,November,2018,14:57:59:32438
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: FOLDING MIRRORS. OK!
Mileage: 2907km-1806mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 42 44 52 5F BB BC
VIN: WVWZZZAUZKPCICLOW   Mileage: 2907km-1806miles
42-Door Elect, Driver -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
BB-Door Rear Drv -- Status: Not registered 0001
BC-Door Rear Pass -- Status: Not registered 0001
Address 01: Engine (J623-DKRF)       Labels: None
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000
   Coding: 01190032232415082000
   Shop #: WSC 00028 028 00070
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC92FE9B-807C
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733020F078C002430B00000012121212B835351919323200
   Shop #: WSC 00028 028 00068
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6D7B49-8022
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Component: Climatronic   H04 1801
   Revision: 00001K08
   Coding: 00020003200110011005000000101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006145
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 6C8139CC460C1C0752D-8038
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 5Q0 937 084 DA    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H38 0273
   Serial number: 00001820800697
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7AAD0F943C58B2B7D01-802E
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043 0551
   Serial number:         180705074106
   Coding: 0E4DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052 0107
   Serial number: SBY18M08D06H04M32S34
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000002081804401346
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418018193
   Coding: 0471151001
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000_009_VW37.rod
   VCID: 4CC1994C264CFC0732D-8018
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2B00600111FFC728949C810500400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 44D1B16C0E1C3447FAD-8010
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 094F605869BEA92FC9B-805C
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Side Sensor Driver Front:
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 740 D    HW: 5G1 920 740 D
   Component: KOMBI         211 2500
   Coding: 07A52A002380000801883A011401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009065
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 270B06E09F6AFF5FFFF-8072
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 14071810801894
   Coding: 030100047F085700FA000248080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013023
   ROD: EV_GatewNF_VW37.rod
   VCID: 3D27C4886DF6458FB53-8068
   Alternator:
   Component: 1-01-02-01-04
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5G0 959 442 AA    HW: 5G0 959 442 AA  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39180001255750088264
   Coding: 28FFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
   Component: TSG FS        005 0240
   Serial number: 42018727800277
   Shop #: WSC 17301 666 28888
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 011F0000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B322B01B32C3FF937-8026
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000336638884
   Coding: 00110120DE00048000001000
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 47CBA6603F2A1F5F1FF-8012
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      724 0890
   Serial number:
   Coding: 02731000FF0000005111000100080A001F0500D40120010003
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2D07F4C8BD96D50F053-8078
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H52 8130
   Serial number: VWZ6ZJV2140047
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
End----------(Elapsed Time: 01:16, VBatt start/end: 14.4V/14.4V)-----------
I finally made a video that shows how they work :arrow: viewtopic.php?p=583982#p583982 😁
Golf 7.5 Light Assist (basic). High Beam Assist (HBA/FLA).
Original Mirror Y7
Remove/Isolate T8/3 (reverse signal).
HBA mirror.
Run the two new wires for CAN lines (extended. T8/3, T8/8) through the A pillar to the TIUL coupling point (Black connector).
Coding:
-Light Assist, FLA, HBA (basic). G MK7.5 "08/2018-->" Part No 'SW': 3G0 857 511 BD.
 Address 19:
 Installation List, enable Address 20
 Address 20:
 Coding
 LC, 0101000000000000000000 (Halogen headlights)
 LC, 0202000000000000000000 (Bixenon headlights)
 LC, 0404000000000000000000 (LED headlights)
 Address 09:
 Adaptation
 Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP,present ,6 (present)
 Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,Basis ,6 (Basis: FLA) -extended control for High Beam.
 Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not Present ,6 (present) -menu
 Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6 (present) -menu
 Fernlicht_assistent-Fernlichtassistent Reset,not active ,6 (NOT ACTIVE) ...with 'not active' the system will remember your last lights setting.
Autoscan
Sunday,23,December,2018,10:20:14:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: LIGHT ASSIST OK!!!
Mileage: 5331km-3312mi   Repair Order:
Scan: 01 03 08 09 10 13 15 17 19 20 42 44 52 5F BB BC
VIN: WVWZZZAUZKPCICLOW   Mileage: 5331km-3312miles
   Revision: D7H20000
Readiness: 0110 0001
   Revision: 00001K08
   Air quality sensor:
   Coding: 0E4DDD
   Coding: 03A8DD
   Coding: 0471151001
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Alternator:
   Coding: 28FFFF
   Part No SW: 3G0 857 511 BD    HW: 3G0 857 511 BD
   Component: FLA           H01 0010
   Revision: AA001001
   Coding: 0101000000000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 6B833AD043021B3F5B7-803E
   Coding: 010000
   Coding: 011F0000
   Coding: 090000
   Serial number:
Cannot be reached
Cannot be reached
End----------(Elapsed Time: 01:18, VBatt start/end: 14.6V/14.6V)-----------
Golf MK7.5 Halogen headlights, some bolts and other things.
Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/pBnayJa3R ... autoplay=1 :)
TESTs
Golf MK7.5 Replica LED Headlights. WTF TESTs. Xenon or LED D2H Lamps (HB/LB).
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/h_-Py9XAd ... autoplay=1
1% = -10cm of inclination (10m). ECE only.
- The installation of these Replica LED Headlights is due exclusively to the DRLs and dynamic turn signals look (same/similar as OEM LED headlights).
You can see them here :arrow: here (Golf mk7).
In no case is it due to the installation of HID xenon kit or LEDs lamps in the internal projectors (HB/LB).
- As 'm in the testing process, I will also do the tests for a HID xenon KIT (6000K, 55W) included in the purchase of these Replica LED Headlights. :mrgreen:
There are several things to improve in these Replica LED Headlights.🙂
To be continued...
Willni
Drives: Polo '14 6R, Golf 07' Edition 30
Post by Willni »
Mk7.5 golfs are a lovely driving car and well built, I had a 1.5 TSI for a week and handed back to get a GTD, because I knew I'd spend more on retrofitting than the price difference lol. Goodluck in the tests!
Hi Willni, enjoy your GTD! 8) , my wife's Golf 1.0 TSI Ready2Go already had from the factory all the equipments we needed and much more (VW 👍).
I agree with you, it's very very well built.👌
The rest of recently added parts are because I currently have more fun installing them than by driving this excellent car (or any other).
I've already had very top range cars (Audi, etc), with them I paid an extraordinary annual amount of insurance. Then come the speed limits, and a long etc ...
e.g. 400HP to not exceed 120 Km/h... HARD to swallow... always with the tight ass 😁 to avoid receiving fines. (each one we have our level of this)
The tests I am currently doing aren't to have luck, they're to get knowledge about the things are manufacture in this world.
Anyway, thank you.🤝
Willni, your soul already know that I can have the best Golf mk7.5 of the world if it was my purpose... 😂(just kidding)
At the moment it's the best mk7.5 Ready2Go of the world, included others G MK7.5 low range models.
Made with my 'hands' 💗, and without be possible from factory.
:arrow: Passion
The best is yet to come... or not.🤪
https://www.drive2.ru/o/b/2618999/
Once I have read the above good report, it seems that the projectors installed in these Golf MK 7.5 Replica LED headlights are original Hella 3.
Roughness in the lens indicates it, still to checking many other things ...🕵️‍♂️
VW 8P0 941 621
other info
VW 5G0 941 119 (L) , 5G0 941 120 (R)
hmthakur
Drives: Polo gt tsi 1.2 dsg
Post by hmthakur »
R these xtra rubbers for proper fitting??
Yes, they were not included in the headlights purchase.
Small improvements that make a difference.
Electrical tests in my Replica LED headlights with the HID xenon Kit included in the purchase have been completed:
Good results 👍
- The consumption (Amperes) for all the lights is the same or lower than with the Original Halogen Lights. (HB + fl, LB, BLK, SD/P, DRLs)
- The operation of side lights/parking lights, daytime running lights, and dynamic turn signals are close to perfection (awesome).
- The HRCMs work perfectly.
Bad results 👎
- Once I turn on Low Beam with the light switch, takes 5 seconds or more to reach the optimal operating color/temperature (the color is white as sunlight✅).
This is not good, for example, with automatic lights system or the obligation to turn on the lights for tunels/shadows/dark/etc...
- A fault is detected in High Beam lights (logically), it's shown in the MFD and in the info system (5F). This fault can be solved with VCDS easily (adaptation).
As I must use the VCDS for HB adaptation, and the results are as I expected, I bought another HID xenon Kit just when received the LED headlights with the HID xenon Kit included.
This one:
:arrow: "Yeaky" ... i chose 5500k D2H
It's faster for turn on the LB (1s quick start... we'll see :) ... waiting to recieve it)
This new HID xenon kit doesn't have the black box -SUPER DECODER-, as you can see in the previous link, ...it's perfect, IMHO is an unnecessary monstrosity if you have VCDS, ... it'll be necessary to adapt HB and LB ... easily. :lol:
Locked
