Please help with this eBay central locking diagram
Re: Please help with this eBay central locking diagram
Yes, based on what you have now
You might have to pop the housing off though. The RCN210 has a strange fakra fitting
Orel
Drives: 9n3
Post by Orel »
Yeah, I searched a lot and I didn’t find the connector for the rcn. I hope it will fit
Normally the RCN has a normal single fakra plug. Id be surprised if the one you have ordered came with what was pictured as its uncommon
Orel
Drives: 9n3
Post by Orel »
Sorry but I don’t understand which one I need because there is more than one type of fakra
order the one you pictured :)
Orel
Drives: 9n3
Post by Orel »
Thank you very very much I’m really appreciate it
gerinemo
Drives: Polo 9n3
Post by gerinemo »
late to the party
I have the rcn 210
The silver connector on the rcn210 where the aerial goes just pulls off and the adapter that Orel posted with the blue plug goes straight on
Hope this helps
I can post a picture tomorrow if it helps
Orel
Drives: 9n3
Post by Orel »
alexperkins wrote:180 ohm resistor on the open wire in line with the blue/white wire you have already connected the lock wire to
See the last two pages
http://f.shortnd.it/ukp/vw_polo.pdf
Just now had the time to install the resistor and it’s working!! Thank you !!
And what about the windows? Which wire I need to plug?
DaveSmith
Post by DaveSmith »
alexperkins wrote: Wed Jan 30, 2019 11:25 am You can normally pick the wire up from the loom going near the bonnet pull that runs down along the drivers side footwell
Hi . Sorry for dragging this thread back up. I'm pretty basic at my wiring knowledge and skills . But I'm about to throw a universal eBay key fob kit in my 2 door . The haynes manual says there is a high and low coming from the door lock module am I to assume that's the wrong place for me to be looking at wiring in my new Central locking unit . I know about placing the resistor in line but my question is do I place the unlock and the lock wire to the single wire just having one directly soldered to the wire and the other soldered to the resistor then to the wire. ? The rest is basic enough for me to understand just not getting the part regarding placing the resistor to either unlock or lock wire then to the blue and white wire from the car. Any help would be so greatly appreciated. Thank you
Dave
Both to the same wire. One with the resistor inline, one without as detailed above
