UK-POLOS.NET - THE VW Polo Forum • 5000K bulbs - Page 2
Page 2 of 6
Re: 5000K bulbs
Posted: Fri Feb 01, 2019 5:11 pm
by alexperkins
Depends how much you fancy spending but the Philips H7 LED kits on amazon are around £130 and give a superb beam as they are a proper bulb. So long as you remove them for MOT, it’s fine
Re: 5000K bulbs
Posted: Fri Feb 01, 2019 6:19 pm
by Adam_013
alexperkins wrote:They don’t look like that though. I have a set in my TT high beams
The higher the K the lower the light output so whilst it looks good, it actually reduces visibility.
I agree .. I went for the Osram 80w bulbs and as much as they are whiter, visibility is much worse. They shine the same distance but not as bright.
Sent from my ONEPLUS A3003 using Tapatalk
Re: 5000K bulbs
Posted: Fri Feb 01, 2019 8:48 pm
by reyonalmighty
Hi Andy,
Iv already got the Phillips bulbs you want to order as my dipped beams. I’ll post some pics so you have an idea of what your getting and iv also got the Osram for my high beams. Let me know what you think. Iv had the bulbs in for about 7 months now.
Re: 5000K bulbs
Posted: Mon Feb 04, 2019 9:14 am
by Andy Beats
Yup, that's the set up I will have
The 5000K Phillips bulbs on dip, the 4200K Osrams on main.
Re: 5000K bulbs
Posted: Tue Feb 12, 2019 9:09 am
by Andy Beats
Here's the 5000K Philips bulb compared with standard.
No need to tell you which is which.
I've got this bulb change down to a fine art now, headlights out/changed and back in in minutes.
Re: 5000K bulbs
Posted: Tue Feb 12, 2019 10:32 am
by Cadwest
Andy Beats wrote: Tue Feb 12, 2019 9:09 am Here's the 5000K Philips bulb compared with standard.
Looks better Andy, have you changed the fog light bulbs yet and if so what bulbs have you used, cheers.
Re: 5000K bulbs
Posted: Tue Feb 12, 2019 10:38 am
by Andy Beats
Cadwest wrote: Tue Feb 12, 2019 10:32 am Looks better Andy, have you changed the fog light bulbs yet and if so what bulbs have you used, cheers.
No, not touching those.
Re: 5000K bulbs
Posted: Tue Feb 12, 2019 1:12 pm
by Scotty_boy vw
Andy do you have a link to the 2 sets of bulbs you have upgraded to? They look great.
Scott
Re: 5000K bulbs
Posted: Tue Feb 12, 2019 1:17 pm
by Andy Beats
Scotty_boy vw wrote: Tue Feb 12, 2019 1:12 pm
Scott
https://www.powerbulbs.com/product/diam ... gKowfD_BwE
Remember and put the GT25 discount code in at checkout to get 25% off.
Re: 5000K bulbs
Posted: Tue Feb 12, 2019 2:11 pm
by blackertracker
Scott
It should be noted that these bulbs are not road legal to use in the UK. They are also dimmer than normal bulbs, putting less light onto the road, despite being a “whiter” colour.
Re: 5000K bulbs
Posted: Tue Feb 12, 2019 2:25 pm
by Adam_013
Scott
I wouldn't worry about the legalities... But certainly aren't as bright on the actual road.
Re: 5000K bulbs
Posted: Tue Feb 12, 2019 2:32 pm
by Scotty_boy vw
Andy Beats wrote: Tue Feb 12, 2019 1:17 pm
Scott
Thank you
Re: 5000K bulbs
Posted: Tue Feb 12, 2019 2:35 pm
by Andy Beats
I was more concerned about getting white light whilst not overloading the wiring.
Really the combo of standard yellow headlights and LED DRLs (which stay on with the headlights) is horrible. :oops:
So these are ideal at 5000K and 55W.
If they're not as bright as the standard yellow lights, that's overruled by my eyes preferring the white and therefore perceiving it as better.
Re: 5000K bulbs
Posted: Fri Mar 22, 2019 9:14 am
by david.stark
After careful consideration and reading this, I’ve opted for Philips X-treme vision bulbs.
Excellent reviews, a whiter light and more brightness on the road. Should have done this before winter but hey ho!
How does everyone find the fitting process? I’ve had mixed results with cars over the years. Some cars were a piece of cake to change the bulbs and others a nightmare.
Re: 5000K bulbs
Posted: Fri Mar 22, 2019 9:29 am
by Andy Beats
david.stark wrote: Fri Mar 22, 2019 9:14 am After careful consideration and reading this, I’ve opted for Philips X-treme vision bulbs.
Very easy
1. Slacken 2 x torx head bolts under the bonnet, on top of the headlights - you'll see which two by trial and error
2. Thump headlight from the back and it pops out like a dangling eye
3. Either leave the headlight dangling while you change the bulbs, or unclip the wiring loom (one clip) and take the headlight elsewhere.
The bulbs themselves are just a pull/push fit.
When refitting the headlights, make sure you get the bottom tang/clip back into the groove on the car, or the headlight will wobble.
And make sure you get the lines where the headlight meets the wing nice before you tighten fully.
