I gave manual a go again to drive home tonight. Using right paddle for upshifts and pulling back on the lever for downshifts seemed far more intuitive than using the stick exclusively for ups and downs.Andy Beats wrote: ↑Wed Feb 13, 2019 4:22 pmWe've both been watching too many rally videos with sequential boxes...monkeyhanger wrote: ↑Wed Feb 13, 2019 3:53 pm I would also have preferred if they'd made the +/- the other way around, I would have liked up-changes to be back on the stick and down changes to be forward.
My thoughts on the DSG and the driver profiles
Re: My thoughts on the DSG and the driver profiles
- Drives: 2018 1.0TSI 5spd
This is the part that i find strange. Sport mode sounds like it's working as it should.
Never used paddles, but the start-stop never bothered me on a DSG until i used one for a while when my Octavia was getting a new gearbox due to failure under mechanical warranty. Hated how it would stop as I approached an intersection only to almost stop as traffic was moving and then having to wait for the engine restart. At least in a manual you can control it so it won't do that without having to turn it off completely.monkeyhanger wrote: ↑Wed Feb 13, 2019 1:58 pm My only complaint with it is not switching over to full manual mode while using the paddles. If you drop a few cogs with the paddles and then floor it in 3rd you've selected, I don't expect the car to think " actually, I think you wanted 2nd, right at the top of the rev range" - No, I didn't!!! Oh and deciding to cut in the stop-start before you come to a complete stop.
- Drives: AW GTI with MT
My old A4 with 2,5tdi and tiptronic was same as you describe ... worst part was that normal would be driving in town in 4th gear and sport is 2nd ... 3th gear was useless as hellAndy Beats wrote: ↑Wed Feb 13, 2019 9:19 am Not sure about current DSG, but I'm sure this is how sport mode worked in my 2005 Audi A3.
Sport mode would hold the car in a gear at higher revs, other modes would change up a gear.
It makes sense as you've told it you want to be sporty and dragging along at low revs/high gear isn't sporty.....
I found sport mode too revvy and fussy for town driving.
- Drives: Polo GTI 2,0 DSG
Hi Monkeyhanger. So no matter what driving profile you're in you're able to change the gear settings by pulling the DSG shift in auto towards yourself? Cause sometimes I would like it to be in D mode and then be able to change into sports gearing without changing profile and visa verse?monkeyhanger wrote: ↑Wed Feb 13, 2019 11:20 am To get the throttle response of Sport, without the "S" gear change thresholds which hold high revs, I put my GTI+ into Sport mode and then pull back on the gear lever against the spring, which puts the gear change thresholds back to normal, denoting "D" e.g. D1, D2, D3 etc. instead of S1, S2, S3. If you want to be back in S mode then pull back on the gear lever again (but I wouldn't).
Your car should remember you're in Sport mode next time you turn it on, but should be keeping the change thresholds in "D", unless you change your driving mode out of and back into Sport during the journey - then the gearbox will revert to "S" changes.
Similarly, if you've been using the paddles in manual mode, and want to revert back to D from M quicker than the car will (it seems to be a 20 second wait), you can pull back on the gear lever again.
Sports mode with S gearing just feels so terrible for city driving :/
^ Yes you can. I never stay in "S" mode for gear changes, "D" reacts every bit as quick with your foot down and will rev the full range to upchange if you've put your foot down. Just pull gear lever back towards you (it's sprung, so will return to same resting position).
I believe that the car has to be in Sports mode for you to be able to select "S" - I don't know for sure as I'm never out of Sport mode on driver selection.
- Drives: R-Line and Gti+
I only noticed yesterday while tinkering that Eco mode shows E before the gear number rather than D or S......Interestingly it reset to D even though it was in Eco mode still after turning off and back on again.
My start sequence. Push button to start car, allow it a few seconds to settle, press driver select mode and select Eco, push Auto stop start disable. Plug in Ipone and select my tunes. In Eco if in need sport for a few moments I simply pull back on the gear knob and it gives me sport mode another tap back and im back in Eco. I find I get around 60 MPG at the moment and in sport the 115hp engine is just about able to keep up with most normal cars on a 0-40MPH quick burst.
Here I would say when I switch off the engine it reverts back to normal mode when I restart so have to go through my start sequence every time I start my car.
I am going to try the set it in sport and tap back gear stick to normal to see if this does actually work. By the way has anyone been able to tell the difference between the Sport setting as far as steering weight goes?
You've saved my next 3 yearsmonkeyhanger wrote: ↑Tue Feb 19, 2019 1:58 pm ^ Yes you can. I never stay in "S" mode for gear changes, "D" reacts every bit as quick with your foot down and will rev the full range to upchange if you've put your foot down. Just pull gear lever back towards you (it's sprung, so will return to same resting position).
