Page 2 of 2
Re: Polo 9n SDI 02
Posted: Thu Mar 21, 2019 4:41 pm
by Dutcho
And only fuse blown in the drivers side slot was cigar lighter
Re: Polo 9n SDI 02
Posted: Sat Mar 23, 2019 9:37 am
by Dutcho
Had a guy from a garage pop round and put his snap on reader onto car. It pulled about 17 fault codes with 4 saying defective ECU so all these problems might be down to a dodge ECU
Anyone paid to have one repaired before ?
Re: Polo 9n SDI 02
Posted: Sat Mar 23, 2019 10:08 am
by alexperkins
You need a proper scan with VCDS and pop the results up on here. There aren’t ‘defective’ ECU codes
Re: Polo 9n SDI 02
Posted: Sat Mar 23, 2019 10:17 am
by RUM4MO
If in the end it does end up being a faulty engine ECU, there are places like BBA REMAN that, it is said, will repair your unit if it is possible and return it to you so that it can get refitted and all its original programming is still intact.
Edit:-
http://www.bba-reman.com/gb/index.aspx
Re: Polo 9n SDI 02
Posted: Sat Mar 23, 2019 1:57 pm
by Dutcho
alexperkins wrote: Sat Mar 23, 2019 10:08 am
Unfortunately I don't have a full version for vcds I'm very cautious about throwing more money at the car as well
Re: Polo 9n SDI 02
Posted: Sun Mar 24, 2019 11:31 am
by Dutcho
Well buit the bullet and cracked open ecu. No signs of water getting in there ?? Doing my head in do I take the gamble whats testing cost ?
Re: Polo 9n SDI 02
Posted: Sun Mar 24, 2019 12:46 pm
by RUM4MO
Contact places like BBA REMAN directly for a price.
Re: Polo 9n SDI 02
Posted: Sun Mar 24, 2019 12:47 pm
by alexperkins
I’m still going for a bad earth somewhere
Re: Polo 9n SDI 02
Posted: Sun Mar 24, 2019 2:33 pm
by Dutcho
Re: Polo 9n SDI 02
Posted: Mon Mar 25, 2019 11:49 am
by Dutcho
Solved ..... dodgy egr fuse that tested ok continuity wise but not under load very weird but sorted just a engine flush now and back on the road cheers for all your help
Re: Polo 9n SDI 02
Posted: Mon Mar 25, 2019 6:28 pm
by alexperkins
Excellent
Glad its sorted
