Seat Ibiza 6j Upgrading BCM and Auto light with CH/LH
Re: Seat Ibiza 6j Upgrading BCM and Auto light with CH/LH
Skyscript wrote: Thu Jun 20, 2019 12:10 pm 1 Were the problems with the fog lights and climatronic caused by the wrong coding?
2 Is it possible to activate the interior light only when it is dark?
Thank you a lot
1 Yes to 99%, the other 1% depends on the electrical installation you did, which seems to be totally correct.
2 No ... :), only curiosity, why don't you want them to be lit during the daylight?
Skyscript
Drives: Seat Ibiza 6j
Post by Skyscript »
It is just unnecessary that the interior lights light during the day. But not a big problem, thought it would be easy to code :D
Another question, it is easily possible to retrofit the cruise control. However I do not know which Cruise combi switch I can take.
6R0953507G should fit according to my knowledge. However, I think the 6C0953513B looks better. are both compatible ?
However, step after step. First of all, I'm happy when the new bcm runs smoothly. 8)
Ok, although there are conditions during the daylight in which interior lights are necessary. (shadows, garage, etc)
In PQ25 the electrical supply for the interior lights (dome, glove box, trunk, etc) is made by the same wire, so individual coding is not possible. The operation of each of the interior lights is conditioned according to how the ground wire is connected.
Installing the cruise control is easy compared to the electrical installations you have already done.
6C0953513B "is not possible" in OEM way.
The best thing you can do for your future retrofits is to buy the original VCDS, someday you will remember that I warned/recommended you.
You will need it to erase intermittent failures when modifications are made, etc, etc, etc... IMHO it is better not to depend on your friend for this.
Skyscript
Post by Skyscript »
Okay, I'll stay with the oem version.
My Ibiza is not from 2014, it's from 2013, is the part number the same?
I would like to have vcds myself. Unfortunately, this is quite expensive and I am still a student and can not afford it at the moment. Of course it would help a lot. I am currently satisfied that I have someone who can code it in general.
Thanks for your help
Fahrzeug-Ident.-Nr.: VSSZZZ6JZER007887
https://en.wikipedia.org/wiki/Vehicle_i ... ion_number
Your Ibiza was manufactured in 2013, but it is a 2014 Model Year (E, tenth digit of the VIN), which serves among other things to identify correctly all the parts installed in your car.
For example, the Cruise Control stalks/levers for Ibiza 2013 MY can not be installed on your Ibiza.
Hmm... write to Santa Claus and ask for the VCDS next Christmas. :lol:
Skyscript
Post by Skyscript »
I did not know that cool.
I have just bought the cruise control stalks / levers on ebay, will study the wiring today and then post here.
You seem to have generous parents. :D I do not get such expensive gifts for Christmas.
In the longer term you are right and I definitely have to buy it myself.
But the little money I currently earn besides my studies has to be used as efficiently as possible. :D
For some years now I am the one who imitates Santa Claus during the Christmas season ... 🎅 :lol:
Skyscript wrote: Mon Jun 24, 2019 1:02 pm
8)
Skyscript
Post by Skyscript »
You are Santa Claus on this forum all year long. :lol:
I've looked at the wiring now and I think the wiring should look like this:
T41/31 --> T2s/1 --> T2s2 --> T73b/46 ( T2s/1 <--> T2s2 | J54 - Automatic distance control system diode | Do i need this specific diode or can i use a normal 12V diode ?)
T41/30 --> T73b/44
T41/27 --> T73b/47
T73b/45 + T41/26 + T41/29 --> T94/45
T41/28 --> A199 (Currently not sure where I connect it best)
is the cabling correct?
The diode is not necessary, currently it is not installed in several PQ25 models.
Skyscript
Post by Skyscript »
Hey ciclo,
Sorry for answering that late.
I already have the new cruise control stalk / lever and prefabricated the wiring.
Tomorrow I will finally test your coding.
And as promised, here's a scan of the old BCM
The fault codes were caused by me and can be neglected.
Donnerstag,28,Februar,2019,11:20:30:56266
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 7 x86
VCDS Version: DRV 18.9.0.2  HEX-V2 CB: 0.4437.4
Datenstand: 20181017 DS296.0
Betriebsnummer: 123 12345 123456
Fahrzeug-Ident.-Nr.: VSSZZZ6JZER007887   KFZ-Kennzeichen:
Kilometerstand: 107460km   Reparaturauftrag: Michael Ibiza
Fahrzeugtyp: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
Fahrzeug-Ident.-Nr.: VSSZZZ6JZER007887   Kilometerstand: 107460km
01-Motorelektronik -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: Fehler 0010
09-Zentralelektrik -- Status: Fehler 0010
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
4B-Multifunktionsstg. -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CBZB)       Labeldatei:. DRV\03F-906-070-CBZ.clb
   Teilenummer SW: 03F 906 070 GR    HW: 03F 907 309 AE
   Bauteil: SIMOS10.22AH10 5485
   Revision: --H10---    Seriennummer:
   Codierung: 001100D6200400080000
   Betriebsnr.: WSC 00049 770 00143
   ASAM Datensatz: EV_ECM12TFS02103F906070GR 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 78A81887725EF767A65-802C
Kein(e) Fehlercode(s) gefunden.
Readiness: 0000 0000
Adresse 03: Bremsenelektronik (J104)       Labeldatei:. DRV\6R0-907-37x-ESP90.clb
   Teilenummer SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Bauteil: ESP9.0i front H02 0002
   Seriennummer: --------------
   Codierung: 11DD287D212300C7881C1471845800480905
   ASAM Datensatz: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F7A435B67D0D0DF17F-805A
Adresse 04: Lenkwinkelsensor (G085)       Labeldatei:* DRV\6R0-959-654.clb
   Teilenummer SW: 6R0 959 654     HW: 6R0 959 654
   Bauteil: LENKW.SENSOR  H07 0070
   Seriennummer: 29051304651073
   Codierung: 01
   Betriebsnr.: WSC 00000 000 00000
   ASAM Datensatz: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA40E9F507AC957EC9-802A
Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei: 6R0-907-044.clb
   Teilenummer SW: 6J0 820 043 E    HW: 6J0 820 043 E
   Bauteil: Climatronic   H03 0808
   Revision: S0000000
   VCID: 261406FFE8EAB197C49-8072
1 Fehler gefunden:
00457 - Steuergerät für Bordnetz (J519)
            013 - bitte Fehlerspeicher auslesen - Sporadisch
             Umgebungsbedingungen:
                    Fehlerstatus: 00101101
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 191
                    Kilometerstand: 107449 km
                    Zeitangabe: 0
                    Datum: 2013.07.20
                    Zeit: 20:22:16
Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\6R0-937-08x-09.clb
   Teilenummer SW: 6R0 937 087 P    HW: 6R0 937 087
   Bauteil: BCM PQ25 H+4  H34 0411
   Revision: BF034001    Seriennummer: 0581 145132630
   Codierung: 7A882BE888610100002008F07E4B9DD80040422F608C0000200000000000
   VCID: 4ACC924F5CB2B5F7001-801E
   Subsystem 1 - Teilenummer: 1K0 955 559 AH  Labeldatei: DRV\1K0-955-559-AG.CLB
   Bauteil: RLS 210311 05  54  0403
   Codierung: 02242D
   Subsystem 2 - Teilenummer SW: 6R0 959 801 AJ    HW: 6R0 959 801 AJ  Labeldatei: 6R0-959-801.CLB
   Bauteil: J386__TSG_FT  006 5110
   Seriennummer: 12202557130528011642
   Codierung: 020000
   Subsystem 3 - Teilenummer SW: 6R0 959 802 AQ    HW: 6R0 959 802 AQ  Labeldatei: 6R0-959-802.CLB
   Bauteil: J387__TSG_BT  006 5110
   Seriennummer: 12202560130528060752
   Codierung: 020000
3 Fehlercodes gefunden:
03302 - Rückmeldung Schließzustand Beifahrertür
            008 - unplausibles Signal - Sporadisch
                    Fehlerstatus: 00101000
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 183
                    Kilometerstand: 107287 km
                    Zeitangabe: 0
                    Datum: 2013.07.13
                    Zeit: 20:08:04
01044 - Steuergerät falsch codiert
            000 - -
                    Fehlerstatus: 01100000
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 255
                    Kilometerstand: 107462 km
                    Zeitangabe: 0
                    Datum: 2013.07.21
                    Zeit: 10:54:19
02195 - Regler für Beleuchtung - Schalter und Instrumente (E20)
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 5
                    Verlernzähler: 191
                    Zeitangabe: 0
                    Datum: 2013.07.20
                    Zeit: 20:22:17
Adresse 15: Airbag (J234)       Labeldatei:| DRV\5K0-959-655.clb
   Teilenummer SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Bauteil: VW10AirbagA09 H10 0020
   Revision: --------    Seriennummer: 003GX01R7U4Z
   Codierung: 003039
   Betriebsnr.: WSC 00049 770 00111
   ASAM Datensatz: EV_AirbaVW10BPAVW250 A01001
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACC924F5C32B5F7001-801E
   Crashsensor für Seitenairbag Fahrerseite:
   Seriennummer: 3495RRB400250GJ2OPQ.
   Crashsensor für Seitenairbag Beifahrerseite:
   Seriennummer: 3505RRB401650HHORH3R
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:| DRV\5K0-920-xxx-17.clb-SRI1
   Teilenummer SW: 6J0 920 806 K    HW: 6J0 920 806 K
   Bauteil: KOMBI         H01 0709
   Seriennummer: 00000000000000
   Codierung: 110E01
   ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A04723
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 3430ECB72EB6D3074AD-8060
Adresse 19: Diagnoseinterface (J533)       Labeldatei:. DRV\6N0-909-901-6R.clb
   Teilenummer SW: 6N0 909 901     HW: 6R0 937 087
   Bauteil: GW-K-CAN TP20 H34 0411
   Revision: BF034001
   Codierung: 022200
   VCID: 70B820A71AAEAF276E5-8024
Adresse 25: Wegfahrsperre (J334)       Labeldatei:| DRV\5K0-920-xxx-25.clb
   Teilenummer SW: 5K0 953 234     HW: 5K0 953 234
   Bauteil: IMMO          H01 0709
   Seriennummer:
   Codierung: 000000
   ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8C32CF3CF255F7201-803E
Adresse 44: Lenkhilfe        Labeldatei: DRV\6Q0-423-156.clb
   Teilenummer: 6R0 423 156 C
   Bauteil: LenkhilfeTRW        V278
   Codierung: 11211
   VCID: 3038E0A7D36EEF272E5-8064
Adresse 4B: Multifunktionsstg.        Labeldatei: DRV\6J0-959-441.clb
   Teilenummer: 6J0 959 441 A
   Bauteil: MF-Modul       0007 0001
   Codierung: 0000002
   Betriebsnr.: WSC 77005 000 00000
   VCID: 313EE5A3DD24E62F21B-8064
Adresse 56: Radio (J503)       Labeldatei:. DRV\5M0-035-1xx-56.clb
   Teilenummer SW: 6J0 035 156     HW: 6J0 035 156
   Bauteil: Radio         H07 0012
   Revision: R0000000    Seriennummer: SEZAZ1N6256030
   Codierung: 010004080203
   VCID: 64905CF7DE5603871AD-8030
Ende--------(Dauer: 01:20, Batt.-Spannung Start/Ende: 12.4V/12.4V)---------
Skyscript
Post by Skyscript »
So I just tested the new coding. Fog lights and rear fog lights work now. Likewise the rain sensor, the fan of the Climatronic and the light dimmer switch. :D
Now I have the following faultcodes :
-still 00457
-00901
-02195 is solved.
and unfortunately automatic light does not work anymore, the light is now on continuously.
Current scan:
Mittwoch,03,Juli,2019,10:12:07:56266
VCDS Version: PCI 18.9.1.0  HEX-V2 CB: 0.4505.4
Datenstand: 20190520 DS296.1
Fahrzeug-Ident.-Nr.: VSSZZZ6JZER007887   KFZ-Kennzeichen: MICHAEL
Kilometerstand: 115560km   Reparaturauftrag: cODIERUNG NEU
Fahrzeug-Ident.-Nr.: VSSZZZ6JZER007887   Kilometerstand: 115560km
   VCID: 78A81887725EF767A6D-802C
   VCID: 0F7A435B67D0D0DF177-805A
   Codierung: 01
   VCID: 7EA40E9F507AC957EC1-802A
   Revision: S0000000
   VCID: 261406FFE8EAB197C41-8072
1 Fehler gefunden:
                    Fehlerstatus: 01101101
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 3
                    Verlernzähler: 0
                    Kilometerstand: 115563 km
                    Zeitangabe: 0
                    Datum: 2013.11.23
                    Zeit: 14:36:17
Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\7H0-937-08x-09.clb
   Teilenummer SW: 7H0 937 090 B    HW: 7H0 937 090
   Bauteil: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Seriennummer: 0571 341130505
   Codierung: 7A8829E88861010001200EF07ECB9FD80F4063A9608C2049200000020000
   Betriebsnr.: WSC 12345 123 123456
   VCID: 2D06F9D3CD1C82CF05B-8078
   Codierung: 07302D
   Codierung: 020000
   Codierung: 020000
2 Fehlercodes gefunden:
00901 - Rückfahrleuchten
            010 - Unterbrechung/Kurzschluss nach Plus
                    Fehlerstatus: 01101010
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 0
                    Zeitangabe: 0
                    Datum: 2013.11.23
                    Zeit: 14:43:49
                    Fehlerstatus: 01101000
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 0
                    Zeitangabe: 0
                    Datum: 2013.11.23
                    Zeit: 14:43:53
   Codierung: 003039
   VCID: 4ACC924F5C32B5F7009-801E
   Codierung: 110E01
   VCID: 3430ECB72EB6D3074A5-8060
   Teilenummer SW: 6N0 909 901     HW: 7H0 937 090
   Bauteil: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Codierung: 022200
   VCID: 70B820A71AAEAF276ED-8024
   Seriennummer:
   Codierung: 000000
   VCID: 6A8C32CF3CF255F7209-803E
   Codierung: 11211
   VCID: 3038E0A7D36EEF272ED-8064
   Codierung: 0000002
   VCID: 313EE5A3DD24E62F213-8064
   VCID: 64905CF7DE5603871A5-8030
Ende--------(Dauer: 01:03, Batt.-Spannung Start/Ende: 12.1V/12.1V)---------
Skyscript wrote: Wed Jul 03, 2019 11:49 am So I just tested the new coding. Fog lights and rear fog lights work now. Likewise the rain sensor, the fan of the Climatronic and the light dimmer switch. :D
-still 00457
-00901
00457 Fault not related to the BCM change. (previous)
00901 Have you installed the wire that goes from T73b/12 directly to the reverse light pin?
Skyscript
Post by Skyscript »
I read that it may be due to the sensor of the climatic pressure (1K0959126D).
Tomorrow I will check the wiring and if necessary change the sensor.
I did not know that I had to pull another cable. I found nothing in ELSA. What do I have to do?
Is that why the light is on continuously?
Skyscript wrote: Sun Jul 07, 2019 4:18 pm I did not know that I had to pull another cable. I found nothing in ELSA. What do I have to do?
Reverse light (Ibiza SC 2014)
- with BCM High
- with BCM Max
So, new wire from T73b/12 to T6/4, isolate original T6/4. EASY!
Skyscript wrote: Sun Jul 07, 2019 4:18 pm Is that why the light is on continuously?
No.
I think the problem is that you still have the T17/3 wire (DRLs) connected to the light switch.
You think the lights are permanently ON, but in reality, your IBIZA SC makes the DRLs (TFLs) through the bulbs of the dipped beam.
Disconnect and isolate the T17/3 wire.
If in the future you install headlights with independent daytime running lights (e.g. with bixenon headlights and independient DRLs module) you must connect a new wire from T17/3 to T73b/29, plus the wires that feed the DRL LED modules.
Skyscript
Post by Skyscript »
I have no Ibiza SC. I checked ELSA and my wiring should be like this :
Left side :
T73b/12 --> T6d/6 RFL
Right side :
T73b/12 --> T6e/2 RFL
Just checked the light switch and nothing is connected to T17/3. There was never anything connected with my knowledge.
With the old coding it also worked correctly.
