Creaking from Dashboard?
Simmo
Drives: 1.0 (95bhp) SE
Re: Creaking from Dashboard?
Post by Simmo »
I have a buzz on the left-hand side of the dash, high up - just above and behind the glovebox.
Its mainly there when the car is starting from cold, especially when accelerating during the first couple of miles - tends to be less noticeable after that.
Had a look from the passenger footwell, plenty of taped wires, black plastics but can't seem to locate it :roll:
Apart from that, seems to be ok so far. If it persists and becomes more annoying then I'll book it into the dealers for them to take a look (together with the clunking brakes!)
alexander.colquhoun
Post by alexander.colquhoun »
Hey all and @marshall_mcf,
Did you figure out this problem at all? I have the identical problem and it’s super annoying as I’ve also been to my dealer twice with various lubrications of the door etc. Am wondering whether it’s the plastic coloured trim itself as pushing it generates a similar noise.
Edit: re read and seen its hopefully the sound actuator! Will see how I go.
Lukefez15
Drives: Polo Gti
Post by Lukefez15 »
I had a very similar issue with mine took them a week to work it out. After taking the whole of the dash out turned out to be the usb power connector bracket should of had 4 clips on but only had 3 this was causing the vibration.
peeceeuk
Drives: Snazzy red GTi
Post by peeceeuk »
I had a rattle that I could swear was coming from the left of the dash.
I had a passenger at one point, he was convinced that it was coming from my side of the dash.
Eventually I tracked it down to being from some sunglasses that I had put in the overhead compartment, sliding and bouncing around.
I don't even wear sunglasses, ever.
Useless compartment for myself.
OomStu_ZA
Drives: 2019 VW Polo GTi
Post by OomStu_ZA »
Lukefez15 wrote: Mon Sep 09, 2019 8:31 pm I had a very similar issue with mine took them a week to work it out. After taking the whole of the dash out turned out to be the usb power connector bracket should of had 4 clips on but only had 3 this was causing the vibration.
VW almost had to remove the dash in my last 6C to fix an annoying rattle but lucky they didn't do it in the end. I've heard numerous horror stories of new problems arising once the dealer refits the dash. Hope its all smooth sailing for you mate.
peeceeuk wrote: Mon Sep 09, 2019 11:39 pm I had a rattle that I could swear was coming from the left of the dash.
Ha Ha, I've been there done that - but it did take quite a while for the penny to drop, in my case it was an S4, it only made that noise when there was no sunshine, pretty obvious when you think about it in my case, but still it took a few months for me to consider that, sunglasses now need to be stored in their protective sleeve until I get round to fitting some soft foam dampers inside the sunglasses storage area.
OomStu_ZA wrote: Tue Sep 10, 2019 9:57 am
Yes, I’ve heard of dealer’s damaging pieces of interior trim when they remove them to get to the source of unwanted creaks and rattles, and then denying they caused the damage. There’s also a risk they’ll create new creaks and rattles in the process.
Always a good idea to take pictures of the interior trim pieces they’re going to remove before they start ripping them out! That way, if they do cause damage, it’s more difficult for them to deny it.
x JustChill
Drives: 2023 GTI
Post by x JustChill »
Sorry to resurrect a dead thread – but I just bought a brand new 2023 GTI and it has exactly the same creak/rattle as @marshall_mcf noticed in that video.
Did anyone, especially marshall_mcf, figure out a long-term fix?
It is driving me nuts, as you may imagine; all the more so because the car itself is so brilliant.
It's going to the dealer this week for the 2nd time since I picked it up.
Any help would be very much appreciated!!
johnparker
Post by johnparker »
This is no help to you but just for reference, ive had my polo from new in 2018 and have never experienced a single rattle or buzz. Good luck in identifying the cause.
x JustChill
Drives: 2023 GTI
johnparker wrote: Fri Jul 21, 2023 5:52 pm This is no help to you but just for reference, ive had my polo from new in 2018 and have never experienced a single rattle or buzz. Good luck in identifying the cause.
It’s actually useful to know, thanks - because one dealer said that it was due to the ‘normal flex of the vehicle’, an idea which I didn’t have much confidence in.
fletch555
Post by fletch555 »
Anybody ever find a solution to this? I'm getting this creak now and it's driving me insane. If I press down firmly on the top of the dash, just to the right of the air vent it stops the noise. Just wondering how I could solve it (as it's not practical to be pressing on the dash permanently as I drive :lol: )
Dreamscape
Drives: 2024 GTI
Post by Dreamscape »
My 2019 Polo had a rattling handbrake button. That was fixed on warranty. Dashboard did rattle a little bit from start, but only in the cold. I guess a little expansion of plastics in higher temps was enough to make a tighter fit, so that it wouldn't rattle. I learnt to live with that.
Jakeuns11
Drives: 2018 Mk6 Polo
Post by Jakeuns11 »
I had an issue similar to this (not sure if it was the exact same as OP), but I discovered that it was the panel where you find the "disable passenger airbag" keyhole. (Far left side of the dash, the panel that is covered by the passenger door when closed.)
I ended up folding a piece of paper and cramming it in the gap of the panel to wedge it and stop any play. This seemed to do the trick. Once I find out how to take that panel off without breaking anything, I'll be looking into a more permanent fix.
fletch555
Post by fletch555 »
So the creaking started to REALLY annoy me! I took off the dashboard cover off. It's definitely more noticeable when the weather/cabin is warm. When the dashboard is creaking, if I press my finger down on the area circled in red, it stops. I took a look in under and there appears to be a screw/bolt attaching the airbag unit to the dash. Has anyone else had this problem before (and know a solution)? I"m a bit hesitant to go touching anything to do with the airbag.
