Skoda Fabia VRS 2012. Auto lights retrofit OEM
Forum to discuss the Skoda Fabia
VASILEIOS1972
Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
Re: Auto lights retrofit
Post by VASILEIOS1972 »
Light switch connector + switch
VASILEIOS1972
Dimmer switch
I have install dimmer switch with no function in dimming , only light range
gas station near me hours
VASILEIOS1972
DRLs button connector
frost bank atm
VASILEIOS1972
VASILEIOS1972
Front lights H7 dual
VASILEIOS1972
tail lights
VASILEIOS1972
rain sensor + anti dazzle mirror
VASILEIOS1972
I think for the start I gave you enough to guide me
Best regards
VV
I will analyze the information.
At first glance I am clear about what you should do, but it will not be easy, especially the DRLs -new wires from BCM to each DRL + a wire from T10 light switch connector to BCM-.
I seem to remember that your LED DRLs also work as parking/side lights, right?
VASILEIOS1972
ciclo wrote: Wed Jul 24, 2019 9:03 pm I will analyze the information.
yes my friend
VASILEIOS1972
And as you can see in 17 pin head light switch I have
pin 1
pin 2
pin 3
pin 4
pin 7
pin 9
pin 10
pin 11
pin 13
pin 14
pin 15
pin 16
pin 17
so the current wiring diagram that you made must have some serious changes or not my friend?
VASILEIOS1972
Hello my friend again , I am sending you from ELSA what you asked me
the closest shell gas station
best regards
VV
VASILEIOS1972 wrote: Wed Jul 24, 2019 8:22 pm I think for the start I gave you enough to guide me
Best regards
VV
No, it is not enough my friend. As all the VW group parts that are for the same function do not work in the same way you have to tell me the reference number and donor/original car of the following parts:
- BCM Max that you are going to install.
- Interior Dimmer with headlights range regulator that you show in the previous images.
- AUTO Lights Switch you want to install (I imagine it is the one you currently use for the Chinese kit).
This is elementary for wiring installation and BCM Max coding.
VASILEIOS1972 wrote: Wed Jul 24, 2019 9:24 pm
No, the diagram is correct. This should not be your main concern.
Your main concern should be the two additional harnesses for BCM Max adaptation.
Plus the two new wires, from BCM Max connectors to the T3/3 slot in DRLs connetors. (I will draw a picture for you to install these two new wires)
VASILEIOS1972 wrote: Thu Jul 25, 2019 8:29 pm Hello my friend again , I am sending you from ELSA what you asked me
Thank you very much for the information and the effort to post it.
Because of analyzing the information you provided me, I reinstalled the ELSAWIN (only for Skoda) so as not to omit even the smallest detail of the electrical installation that you should do.
In the next post I tell you how this installation process will be, with all kinds of details. Your electrical installation is already in my mind to be a total success.
There are many conditions, but the most important is that I am on vacation and I will not spend a month explaining what you should do to make the wiring.
You will have to admit my conditions.
Please provide me with the requested information.
